D7 3T fuel problems
D7 3T fuel problems
Showing 1 to 10 of 13 results
jd4230ps
Send a private message to jd4230ps
D7 3T won't start, has no fuel at bleed screw on top of filter housing. Ran it yesterday with no problems, this morning started , Ran bout 3 seconds. Fuel was low in tank , had 5-6 gallons left. Fuel pressure has been little low (new gauge) for last year or so. Filters are new. I'm thinking primary fuel pump. Any help would be appreciated. Thanks
Sun, Mar 11, 2018 7:40 AM
Gator
Send a private message to Gator
I had a issue like that with my D8. Had about 20 gallons in the tank. Shut it down and went to start it the next day. She wouldn’t go for love or money. The fuel housing was full and seemed to have fuel squirting out through the lines at the injectors bit it still wouldn’t fire. I pulled the filter and installed a new one. Drained the housing but she wouldn’t self prime. Ended up filling the tank to the top and left the bleed screw out till fuel came. I hit the switch and she fired right up. Hasn’t given me any grief since.
Sun, Mar 11, 2018 10:32 AM
I would start by checking for good flow by gravity only to the inlet of the fuel pump. Usually the easiest way to check that is to drop the inlet block off just unbolt it and crack the gasket loose so it can drop down. Might need to unbolt the fuel line supports back a ways. With that down catch the spring and fuel pressure bypass valve poppet that may fall out into the belly pan.
I am betting a clogged tank valve etc. Of course your gear pump could be shot, running it low may have sloshed fuel around and stirred up enough rust and debris to damage pump. Several folks have posted pictures of a filter installed in the line ahead of the pump to prevent that.
Sun, Mar 11, 2018 10:37 AM
Did you open the lower bleed screw first? allot of guys think just open the top one and good to go, wrong! the lower one gets the air out of the filter housing area first and faster, once thats bled open the top one and get the remaining air out above the the filter plate, then fuel will be up to the port that goes to the injection pump, then open the bleeders at the pumps till all air is out and the engine will fire right up. no need for all this pressurising the tank bs and whatever else.Done it this way and never had problems. With the tank low you might have a blocked shut off valve or fuel line. To check take the line off at the transfer pump and blow it out from the tank or either end.
Sun, Mar 11, 2018 9:06 PM
jd4230ps
Thanks for suggestions every one. Will try them tomorrow and she if it starts.
Mon, Mar 12, 2018 1:52 AM
Reply to jd4230ps:
"no need for all this pressurising the tank bs and whatever else"
I am surprised that you find this method of bleeding a fuel system bs, I use it quite often and I believe many other guys do too.
Mon, Mar 12, 2018 2:00 AM
Reply to dpendzic:
Well I guess whatever works for you then.
Mon, Mar 12, 2018 3:53 AM
8C 361
Just bite the bullet and fill the tank plumb full and it will bleed by gravity.
Mon, Mar 12, 2018 8:15 PM
Machias cat
Send a private message to Machias cat
Reply to dpendzic:
[quote="dpendzic"]"no need for all this pressurising the tank bs and whatever else"
I am surprised that you find this method of bleeding a fuel system bs, I use it quite often and I believe many other guys do too.[/quote]
I have found both methods work fine.
For the gravity flow method the tank needs to be full or have a high enough fuel level to provide sufficient head pressure to flow the fuel depending on how the machine is sitting relative to level ground.
Pressure method is faster as long as you don't over pressurize the tank in the process. The pressure method can disquise flow problems so that can have you chasing your own tail.
I usually use the gravity feed method because it is the easiest.
Mon, Mar 12, 2018 10:47 PM
7upuller
Reply to Machias cat:
Hey Team,
This is what I’ve found to be very very helpful with Cats... Put fuel in them so they don’t run out...:caked:
For those that run tractors with just the last 1/4 tank or less, you’ll find that increased fuel problems occur. Plugged filters, clogged lines, blockages in relief valve, and so on... It’s much easier when the Cat gets to a 1/4 tank to add fuel... less expense and problems.
Mon, Mar 12, 2018 11:04 PM
Reply to 7upuller:
Hey Team,
Make sure the fuel tank cap vent is clean also.
Tue, Mar 13, 2018 2:08 AM
| Hartley - South Australia
