D7e 48a severe underside track wear
Showing 1 to 10 of 46 results
westoz48a
Send a private message to westoz48a
Hi All,i have a few issues with my recent dozer buy(i am still trying to sort the decelerator not working problem as discussed here),the underside of my tracks are wearing metal to metal in the area shown in the pic so are keen to sort it out.I know the undercarriage needs rebuilding when i can afford it but for now would like to replace the parts needed to stop so much wear.I am still learning about the dozer and i know it will be obvious to the experienced here so any help is appreciated,thanks.
Sat, Feb 24, 2018 5:28 PM
catsilver
That's normal when the tracks are well worn and they sink deeper into the sprockets due to bush and sprocket wear, you need to get the tracks measured up for the wear that has taken place to decide what to do next. Should a bush turn be possible, it will give a little clearance at that point, and if the rest of the U/C has life left, it will help extend the life of the system.
Sat, Feb 24, 2018 6:04 PM
Snowcountryfarmer
Send a private message to Snowcountryfarmer
Reply to catsilver:
There are guages available to measure the various undercarriage components, however, it would likely be worth your while to call the dealership and have them inspect it. Here in the USA most dealers will come around and measure your u/c components at no cost, based on the idea that they want to sell you some parts. For the internal wear of the track chain bushings, dealer service techs use an ultrasonic measuring device, which is considerably easier and more accurate than other methods.
Thanks,
Stewart
Sat, Feb 24, 2018 7:13 PM
westoz48a
Reply to Snowcountryfarmer:
Thanks,
Stewart
Thanks catsilver and Snowycountryfarmer for the info,i will call my Cat dealer to see if they can check it out,the left side seems to be wearing more than the right side.I got the dozer at a reasonable price and was aware that the under carriage was well worn,i will get some advice from them to find the cheapest fix until i can afford a rebuild.The undercarriage must be well worn as i have'nt seen any tracks that worn on the net.When i first got the dozer,i took it for a drive and it went well and after found a curved metal shaving on the ground and confused where it come from until i noticed so a lot of wear on the underside of the tracks.I plan to restore it to its former glory and make it work so its a worthwhile investment,thanks again for the help.
Sat, Feb 24, 2018 8:12 PM
bluox
Reply to westoz48a:
Adjust your tracks up a bit and see what happens. Looking at your other pictures the track may be hitting the front rock guards. If you would post some pictures of the idlers .
Bob
Sat, Feb 24, 2018 9:49 PM
DPete
Reply to bluox:
Bob
Off subject but do you know what the rear trunion ball was for? They must have pulled something from them.
1962 D4C
Sat, Feb 24, 2018 10:42 PM
Reply to DPete:
That is caused by low rail height and bottom rollers wore out. Also check the top of the final drive cases, the tracks will wear into the case from constant rubbing from the tracks. Also worn rollers and worn out pins and bushings [bushes] will cause "snaky" rails and cause excessive side wear on rollers and track guides and pin bosses. Best for now to replace bottom rollers and then get new rails and sprocket segments. Yes its expensive to replace these parts but almost everyone that gets and wants a large tractor just wants to run it to death, "do there job" and then sell it, well you have to put money in them to get the work out of them too.
Sun, Feb 25, 2018 1:11 AM
Thank you received: 30
Reply to bluox:
Bob
[quote="bluox"]Adjust your tracks up a bit and see what happens. Looking at your other pictures the track may be hitting the front rock guards. If you would post some pictures of the idlers .
Bob[/quote]
Yes, adjust to get proper tension. If too sloppy, the pads can also hit the top of your final drive housing and scrape the top of it off along with some of the bolts.
Sun, Feb 25, 2018 1:14 AM
Reply to catsilver:
Pins and bushings [bushes] has nothing to do with that type of wear going on there. The sprocket should NEVER be sitting down on the bushings when sitting on level ground.
Sun, Feb 25, 2018 1:15 AM
8C 361
It is not the best picture in the world but I don't see any flat spots on the pin bosses and the rails seem to have good meat on them. A stretched track rides higher in the sprocket under load. I am suspecting a failed final bearing. Is there any oil in your left final?
Sun, Feb 25, 2018 2:23 AM
Wombat
Donor
Reply to 8C 361:
May not be all bad, to me it looks like the rock guards have recently been rebuilt, tracks in reasonable shape. I think just a sign things settling in a bit where they may be overbuilt.
Contact Westrac and ask for a CTS inspection, that is a free service, they will measure tracks for wear and give you a life remaining in %.
My guess the extra trunnion was the tree pusher mount.
Sun, Feb 25, 2018 4:09 AM
Veerkamp Open House 2025
| Placerville, CA
Stradsett Park Vintage Rally
Chapter 2 The Link Club's AGM
