Cat 212 Road Grader questions
Showing 1 to 10 of 14 results
Crg169783
Send a private message to Crg169783
Hello, Been doing a bunch of research on serial numbers and weights. We are sending one to the Ukraine as part of our Non-profit.
First off we bought the first one today. it runs, pony works, generator was bad but the guy put an alternator on it with some custom brackets.
Second we found another one we are looking at buying and keeping to take care of our own roads. Both Run, both are in pretty good shape.
Questions:
Does any body know the weights of the machines?
(Most important due to knowing shipping factors across the ocean)
Years based off serial numbers?
The first one is a tricky one, we think its 9L2976 However I cant seem to find a 9L prefix anywhere (The plaque is very old and hard to see so I could be wrong) The owner says its a 1952 This is the one in the picture
[attachment=47381]20180223_103630.jpg[/attachment][attachment=47382]20180223_102635.jpg[/attachment]
Second is 6F3813 which i understand from online is a 1938-1947, however would like a bit more exact year.
Thanks for all your time in advance
CRG
Sat, Feb 24, 2018 8:05 AM
D4C Charlie
Send a private message to D4C Charlie
I think thats a 9T grader. Sure has some big ol tires, what size are they?
Sat, Feb 24, 2018 8:25 AM
Crg169783
Reply to D4C Charlie:
13.00 x 24
Sat, Feb 24, 2018 8:47 AM
Crg169783
A 9T with a 2976 behind it would mean a 1947?
Thanks!!!!!!!
Sat, Feb 24, 2018 8:51 AM
Reply to Crg169783:
Thanks!!!!!!!
9T2976 would be a 1952 model as the owner stated.
6Fxxxx is not a 212 s/n designation.
Sat, Feb 24, 2018 10:02 AM
Crg169783
Thank you....Any idea on the weight of the machine. Thank you again. 😊
Sat, Feb 24, 2018 10:20 AM
josh
Thank you received: 6
Reply to Crg169783:
Approximate shipping weight of the 9T is 13,670 lbs, plus 980 lbs for the scarifier group.
Sat, Feb 24, 2018 11:27 AM
Thank you received: 34
Reply to josh:
Hi, Crg169783.
It's hard to tell from 10-12,000 miles away but the machine in your 2 photos looks to me like it could be an early 112, a Cat 12 frame with a D4-size engine instead of the D6-size D318 that went in the #12s. The bigger 'tahrs' would fit with that too.
Sat, Feb 24, 2018 12:04 PM
catskinner
Hi, Crg169783.
That looks like a 112 to me also. What size engine does it have, 4 or 6 cylinder? catskinner
Sun, Feb 25, 2018 11:00 AM
josh
Reply to catskinner:
212 is my vote, that frame looks too small for a 112.
Sun, Feb 25, 2018 1:51 PM
old-iron-habit
Reply to josh:
Oh no! Don't look at the front tires.
Mon, Feb 26, 2018 5:05 AM
