Cat 1673 engine....
Cat 1673 engine....
Showing 1 to 9 of 9 results
roerjm
Send a private message to roerjm
Hi all;
I am looking at an Oshkosh Heavy Duty snow plow truck, that has a Caterpillar 1673 engine. I am not familiar with this engine...anyone know some info on this...how would it compare to a 3306 or 3406 Cat engine??? Thanks!! Roland
Tue, Jan 30, 2018 4:32 AM
MARCOTEN
is that a v8??
if so its amost similar to a cat 3208 ( v8 )
those were called the trow away engines from cat,
quality just so so, and not so much in comparison to very good 33 series (3304/3306) and 34 series. 3406-08-12
Tue, Jan 30, 2018 5:45 AM
bursitis
Reply to MARCOTEN:
is that a v8??
inline six dual overhead cams. i had a 1693 in a truck a looong time ago.loved that engine. the 1673 is it's little brother
Tue, Jan 30, 2018 8:31 AM
Thank you received: 14
Reply to bursitis:
What did Cat supply as a 4 cylinder when the 3400 series reigned?
Tue, Jan 30, 2018 8:34 AM
L364
Send a private message to L364
Hello
Caterpillar 1673 truck engine is similar to D6C track type tractor, No14 motor grader and D333 engine.
The 1673B was a 6 cylinder 4.5" bore X 5.5" stroke, 525cu/in @ about 245 Hp. ( 2 valve head ).
The 1673C was a 6 cylinder 4.75" bore X 6" stroke, 638 cu/in @ about 250 or 270 HP. ( 2 valve head ).
The 3306 was a 6 cylinder 4.75" bore X 6" stroke, 638 cu/in @ about 250 or 270 and 300 Hp. ( 2 valve head ).
The 1674 was a 6 cylinder 4.75" X 6" stroke, 638 cu/in overhead cam @ 270 Hp ( 4 valve head ).
Down here they were all used in Oshkosh trucks, i.e. R,s and E models.
Best regards
Tue, Jan 30, 2018 9:15 AM
EL300B
Send a private message to EL300B
Reply to L364:
Hello
Best regards
I have one in a 9u D6 farm cat,real nice engine.
Tue, Jan 30, 2018 11:37 AM
Reply to EL300B:
EL300B, can you post some photos of that 9U - it'd be interesting to see how it's fitted and what accommodations were made
Tue, Jan 30, 2018 7:34 PM
Norm R2,22
Send a private message to Norm R2,22
The farm I helped out on had a KW with a 1693. The first time I drove it, and the turbo spooled up, it sounded like a cop had hit the siren. That turbo was loud.
Tue, Jan 30, 2018 8:53 PM
catsilver
Reply to Norm R2,22:
1673C was the same engine as the D333C/3306.
Wed, Jan 31, 2018 7:04 PM
1693power
Send a private message to 1693power
Reply to catsilver:
If you look in the wanted to buy section, I posted looking for a 1673/1673B back in November, and did not receive a single response. That about sums up the interest in these engines today. They were common block with the D333 equipment and industrial engines, and in certain parts of the US the truck engine and its pieces were used to hot rod the equipment engines, as the truck engine was way higher rating. If you post your engine serial number prefix (70B, 78B, 69R, etc.) it will tell us which one 1673 you have, but these were Cat's first serious foray into the truck market starting in the early '60s. and were smaller engines which were often used to repower trucks with blown up 220 Cummins, as well as in new trucks.
So your engine is a predecessor to 3306 (1673C and 3306 can be literally the same serial number prefix), but at 525 or 638 ci, the 1673 is way smaller and less powerfull than even the most detuned 3406 at 893ci
Thu, Feb 1, 2018 6:52 AM
Veerkamp Open House 2025
| Placerville, CA
Stradsett Park Vintage Rally
Chapter 2 The Link Club's AGM
