wow very nice and quit rare motorpatrol!!!
i would estimate the value is + 5000 usd, and complete restored a lot more, mabe 10.000.usd
on the transmisioncase the is a nr, (see picture a bit of the right of the Arrow)
on the left side on engine where the flat area is , there is the same nr. (see picture you see the nr next to waterpump)
and mabe there are brass plates, look for : PV.... ( pv is for the fifteens then a number from 1 to 4 digits as a serial nr.)
or motorpatrol .....
the first 15's were built in 1929, but not so much, then the most in 1930 and 1931, and the last few were in 1932, then the twenty two came. and fifteen production was stopped.
i have 3 fifteens here and a lot other people here on the board too and we are able help with info you need.also getting it running or restoring.
the Cat TEN is the same design but just a bit smaller in all.
can you post a picture of the operators station please?? i am inteseted if/ how clutch handels and brake pedals are connected...
[attachment=46837]guards (11).jpg[/attachment][attachment=46838]DSC01819.jpg[/attachment]
.webp)
