951b torque converter leaking
Showing 1 to 10 of 19 results
Butch Foster
Send a private message to Butch Foster
Hi All
I'm new here so go easy on me. Got a 951b with the 3304 engine and use a good amount of hydraulic oil leaking from the torque converter, after about 3 hours the temp gauge is on the "hot", let set a 1/2 hour and is good for a hour or 2 for temperature.
I read a old post about the transmission pump not pumping??? Do I have to pul the converter to get to it?
It runs real good till level is to low, fill it up and its good, any and all ideas please
Thank You
Butch
Fri, Dec 15, 2017 7:36 AM
If it's leaking from the front of the torque converter the seal needs to be replaced. Why do you suspect the transmission pump if otherwise everything is working?
Fri, Dec 15, 2017 8:24 AM
Butch Foster
Thank you, have no idea, I haven't climbed under it yet
Fri, Dec 15, 2017 8:30 AM
Butch Foster
Reply to Butch Foster:
It doesn't seem to run out all the time, I've looked under it while running and don't see anything, seeems after shut down, there is a puddle the next day
Fri, Dec 15, 2017 8:32 AM
Thank you received: 21
Hi, Butch Foster.
There is something stirring under a huge bunch of cobwebs right at the back of my skull. I think the torque converter on the 951bs is on the front of the transmission. If I am right, that front seal would be accessible by removing the connecting couplings and pulling the flange.
I am sure that somebody will either back me up or shoot me down in flames. They always do one or the other on here. Thankfully, 'cos I will learn from either.
Just my 0.02
Fri, Dec 15, 2017 9:53 AM
catsilver
Hi, Butch Foster.
Just my 0.02
Correct Deas, the seal is accessible that way, but aleak is usually a sign of the bearing wear, which causes the converter input seals to leak internally and that can cause overheating of the converter.
Fri, Dec 15, 2017 11:57 AM
Reply to catsilver:
Hi, Catsilver.
I was not aware that a leaking seal there could a result or indicator of bearing wear. Never had to go into that area of the jiggers and was basing my answer on observations of several 941Bs, on which I spent a good few very enjoyable hours.
Thanks for the extra information.
Fri, Dec 15, 2017 12:11 PM
Hi, Catsilver.
First order would be to get the external leak fixed.
If that doesn't cure the heating problem there are several other possibilities:
1. Fouled torque converter oil cooler
2. Excessive leakage in the transmission (insufficient oil to torque converter)
3. Weak transmission pump (insufficient oil to torque converter)
4. Excessive clearances in the torque converter (there are no internal lip type seals)(excessive oil build up in the torque converter housing)
5. Failing torque converter (look for aluminum particles in the oil filter)
Sat, Dec 16, 2017 12:37 AM
tctractors
Firstly the 951B is fitted with the 330C engine not the 3304, the front seal on the case can be replaced without to much trouble, it will pay to lift the loader frame right up and support correctly, you have to remove the drive joints (Pucks) then pull off the flange that will move easily, the seal can be dug out without much trouble, the torque cannot cause flood conditions as it's integral with the transmission, the common issue with over heating is the oil coolers, the water has to pass from the water pump through the oil filter cooler to the transmission cooler then into the engine, the engine would also show high temp's, the 951C had the air cooled transmission cooler built into the front Radiator. tctractors
Sat, Dec 16, 2017 4:11 AM
Reply to tctractors:
Hi, tctractors.
I have still yet to operate a 951 of any series. How-wevver, i was told by a bloke who had owned and operated several Bs and Cs - along with a dozen or so 941s - that the Bs were prone to overheating while the Cs ran cool azza cucumber. Maybe that separate transmission cooling core was the difference? Or did they also have a bigger radiator?
Sat, Dec 16, 2017 4:25 AM
tctractors
Hi, tctractors.
The change to Air Cooled Transmission Oil from the water cooler style did reduce the oil temp' also saved the engine over heat from Transmission faults, the water cooler system worked very well but needed good care, the down side of the air cooling system was the 1/4 reduction of Rad core cooling the engine, I found the earlier style cooling to be very good also with the 330C engine fitted the BHP was lower in the B Series than the C's tctractors
Sat, Dec 16, 2017 2:42 PM
| Hartley - South Australia
