Crankshaft Repair for a D6 9U - 3F5020
Ricky
Send a private message to Ricky
number 6 rod bearing failed-spun a bearing , original standard is 3.00"
the journal now measures 2.866"
any suggestions for repair, or is it best to replace, if one can be found
Thanks for comments, Ricky
Thu, Dec 14, 2017 9:17 AM
Thank you received: 14
Ricky, when the journal is an end one, like #1 or #6, it's minimal risk to weld it up and turn it back down to whatever size you have. The risk is around straightening the crank after welding - when it's close to the end, it might not need any straightening. This is information I received from the machine shop I took my 5U crank to, where they built up the rear main journal and turned it back down to std. This shop has been around for years and has worked on a lot of diesel equipment so I was comfortable with their explanation. It's definitely cheaper than a new crank - $250 for the job.
Thu, Dec 14, 2017 9:27 PM
Ricky
I am in North Carolina, where are you located, and would you share who fixed your crank
Thank You, for your reply and your past experience with your crank
Fri, Dec 15, 2017 5:35 AM
Reply to Ricky:
Hi Ricky,
D&H Performance are now part of Caledonia Diesel, 2905 Simpson Rd, Caledonia NY 14423 (585) 538 4395
I haven't dealt with them since they moved from Batavia but I'm sure they're still reputable. I'm in Pittsford NY
Fri, Dec 15, 2017 7:31 AM
janmeermans
Hi Ricky,
Ricky,
Check around for somebody who does re-chroming. I recently had my crankshaft for the pony engine on my D8 14A built back up to standard from .020 under. Not cheap but came out real good.
JanM
Fri, Dec 15, 2017 11:12 AM
timbo1946
Send a private message to timbo1946
Reply to janmeermans:
Ricky,
JanM
I had my crank for my D2 done at RUTTS Machine in Pa. Took a tour of the place when I brought the crank to them. If what I saw wasn't to my liking I wasn't going to leave. Knowledgeable folks and it came out great. Tractor has been running for 4 to 5 years without any issues.
http://www.ruttsmachine.com/
http://www.ruttsmachine.com/services/crankshaft-rebuilding/
Fri, Dec 15, 2017 6:20 PM
Veerkamp Open House 2025
| Placerville, CA
Stradsett Park Vintage Rally
Chapter 2 The Link Club's AGM
