The adjustment procedure is pretty simple. Also, maybe hit up in there with a pressure washer and knock out years of accumulated gunk. You may pull the cover(s) off to lube and soak everything to make sure linkages are free. Lastly - got oil in it ? All of this is free (time only) to try.
Hi, Catfan.
I only have the adjustment instructions for #29 unit but I don't think there is much if any difference in the procedure. Hope it helps'
[attachment=46080]#29 ccu adj #2.jpg[/attachment][attachment=46079]#29 ccu adj #1.jpg[/attachment]
Right click on the image, select "Open In New Window' - when image opens run your mouse cursor over it and there will likely be a + sign in a white circle - click on that to enlarge the image.
I adjusted and sprayed a can of brake cleaning fluid in mine , made a big improvement
Oil and grease leaks are the big enemies of CCU's, once the lined discs have been exposed to either it's really hard to clean them, you can clean the surface but they will weep when warmed up. Adjust as advised if that doesn't do it pull the cover, pressure plate and inspect the discs. Nice straight 14a you have
i once added a few disc sets to a 29 unit and it was much more responsive.
