Where is radiator drain plug on Cat 22?
hidesertman
Send a private message to hidesertman
Can't seem to find an obvious plug underneath the radiator for draining it. Manual says there is one, but where is it hiding? There's this plate thing with a plug-like in the middle on the inside bottom, could that be it? See photo.
[attachment=45985]IMG_20171205_164226789.jpg[/attachment]
Thu, Dec 7, 2017 3:56 AM
Peter C
Send a private message to Peter C
Hidesertman, facing the radiator from the front of the machine, the drain plug is about 3" back (towards the rear) from the front of the radiator and about 3" in (towards the center) from your right side of the radiator. It's inset in the radiator support.
Your picture shows the support for the hand crank for starting. Does this have an electric starter? Just curious.
Pete
Thu, Dec 7, 2017 4:09 AM
thomas84
Send a private message to thomas84
Reply to Peter C:
Pete
Some 22's have a drain valve like this one, bottom right of the radiator. Turn it out a few cranks.[attachment=45998]IMG_1883.jpg[/attachment]
Thu, Dec 7, 2017 8:07 AM
hidesertman
Reply to Peter C:
Pete
[quote="Peter C"]Hidesertman, facing the radiator from the front of the machine, the drain plug is about 3" back (towards the rear) from the front of the radiator and about 3" in (towards the center) from your right side of the radiator. It's inset in the radiator support.
Pete[/quote]
Hi Pete & others, I will check out your suggestions and see! No, this is purely a hand cranker to start...
Mike
Thu, Dec 7, 2017 9:19 AM
Chapter 2 The Link Club's AGM
