Cat D7E #46 hyd relief valve body
Showing 1 to 10 of 10 results
D6 Pete
Hello all ,,, friend up road has just bought a D7E home ,, hyd pump is a front mount #46 ,,, we cant find the ser# tag ,, its very slow lift etc ,, he has just taken front cover off pump ,, and taken a valve body part # 9F3840,,, off ,,, it does look to be groved quiet badly ,,, part is discontinued says Cat dealer here ,,, Any advice !!?? ... Thanks ,,,, pete
Mon, Nov 27, 2017 9:29 AM
That cover and relief valve is used on many (not all) #46 Hydraulic Controls. Is there a number on the housing that might identify it as a Vickers Part?
Mon, Nov 27, 2017 10:10 AM
Ebay says they have one.? Finditparts, Alcoa Tenn.
Mon, Nov 27, 2017 11:41 AM
D6 Pete
Thanks for reply mate ,, its seems to be cat , it has a cat casting # ,, and Cat found it in their parts computer ,, but discontinued !! ,, another friend near by ,, said it will more likely need the cartrage redone ,, he is going to look at it ,, he has redone #44 cartrages ,,, Thanks again ,,,, Cat parts e mailed the parts breakdown pic ,, we don't have a parts book .. Thanks again ,, will look at the ebay part too .. pete
Mon, Nov 27, 2017 12:52 PM
Reply to D6 Pete:
Seems to be a few of them around...
https://www.machinerytrader.com/parts/construction-equipment/search?partnum=9F3840&pst=starts
Florin Tractor looks like a good source.
Mon, Nov 27, 2017 1:01 PM
D6 Pete
Has any body heard of new or recon cartrage for D7e #46?
Tue, Nov 28, 2017 11:24 AM
D6 Pete
Reply to D6 Pete:
Do any body have a #46 parts book ,, caterpillar ,, for D7E,,,, there mayb 2 types ,,, as some D6 U series also had #46 ,, but I guess lower volume apparently ,,, as I have a cat shop manual for it .. ...pete thanks
Tue, Nov 28, 2017 12:46 PM
Reply to D6 Pete:
That would be for the #173 Hydraulic Control. S/n 48Cxxxx that uses a 100 gpm tank/pump similar to the D6 #46 and yes I have the parts book. If this is leading up to pump parts a s/n is required as there are two different pump groups utilizing three different cartridges. Cartridges are all Vickers and individual Vickers parts should have Vickers part numbers on them. Parts are still around (so far) but you have to have the Vickers numbers.
At one time I had the Cat to Vickers cartridge numbers but I can't seem to locate them. Cat should be able to help with that if you can identify by Cat number.
Tue, Nov 28, 2017 1:49 PM
seiscat
I have a service manual for the No. 173 hydraulic controls 48C1 - UP if info is needed.
Craig
Tue, Nov 28, 2017 9:38 PM
D6 Pete
Reply to seiscat:
Craig
I will get the Cartrage number next week ,,we have taken it out ,, its worn fairly bad ,, and the brass end plate is very badly worn ,, a parts guy here has another good one ... and will look at tidy up on the cartrage centre ... pete
Thu, Nov 30, 2017 7:42 AM
Reply to D6 Pete:
Any of the three complete cartridges should interchange, it's just when you replace individual parts that they have to match the cartridge used. Some parts are common to all three, some not.
Fri, Dec 1, 2017 1:07 PM
