Reply to Uncle Rich:
I used a 3 fingered slide hammer puller but had to grind the finger tips to get behind the bushings as they are close to the back wall of the housing. The bushings were very tough to get out and I had to really pound on slide pretty hard. I found bushings from Bronzebushings.com in Detroit Mi. USA for $20 each. The closest size were the right length and ID but were 2mm ,too large OD so I had to turn them down a bit.
All the bellows seals were completely destroyed so I made round aluminum plates that fit into the housings with an inside hole just slightly larger than than the shafts then machined a groove inside and fit an o-ring. I secured them with 4 counter sunk screws I fitted into the seal spring holes after drilling and tapping them. I used the thrust plates and shims to take up space and control the end play. I hope with a lot of grease the seal plates will last a long time and found an Alemite volume grease can to keep them pumped up.
[quote="Uncle Rich"]I used a 3 fingered slide hammer puller but had to grind the finger tips to get behind the bushings as they are close to the back wall of the housing. The bushings were very tough to get out and I had to really pound on slide pretty hard. I found bushings from Bronzebushings.com in Detroit Mi. USA for $20 each. The closest size were the right length and ID but were 2mm ,too large OD so I had to turn them down a bit.
All the bellows seals were completely destroyed so I made round aluminum plates that fit into the housings with an inside hole just slightly larger than than the shafts then machined a groove inside and fit an o-ring. I secured them with 4 counter sunk screws I fitted into the seal spring holes after drilling and tapping them. I used the thrust plates and shims to take up space and control the end play. I hope with a lot of grease the seal plates will last a long time and found an Alemite volume grease can to keep them pumped up.[/quote]
That's interesting as my father also mentioned we could make a similar setup with an o-ring in place of the bellow seals... I like the idea as it would be a cheaper option than getting all new seals.
do you by chance have any photos of the work you did?
