Reply to Casey Root:
Over the years as more of our customers moved to digital photos and acquired photoshop we found that when they submitted photos to us we most often had to ask for the original file.
The larger photos allow the publisher to crop the photo for best interest and optimum presentation.
If you feel the need to color correct, be sure to send the original photo along with the corrected one. Your computer displays in 3 “RGB” color and the print process is 4 “CMYK” color. What may look good on your screen can be pretty poor on press. Today’s press are much more forgiving and things usually come out OK.
Trust the prepress production team. They have a good eye.
Alright gang, sorry for the wait. I was able to get it torn down the rest of the way today.
First the timing cover came off.
[attachment=46177]418D3B99-ECAE-477C-AF5F-0311F424284D.jpg[/attachment]
Since this engine is going to the machine shop I took all the head studs out. This also makes it easier to stand the engine up to take the lower case half off. I use my hoist to lift the case off, mostly because I’m lazy...
[attachment=46178]CC179107-2471-4D93-A016-7D9AF05B9EC3.jpg[/attachment]
Now it’s been said before but it’s worth mentioning again, there are (4) special spacers that go between the case halves. One for each main bearing stud. Their purpose is to keep the proper distance between the case halfs, if they’re not there the bearings get squeezed tight to the crank. They’re sometimes stuck to the lower case half and they blend in with the gasket. So as soon as you get the case split, stop, find the rascals and get them put where you won’t lose them.
[attachment=46180]306D6745-A25B-4218-9C61-76C972E8A692.jpg[/attachment][attachment=46179]B078A84B-7934-4F5C-B878-F607D91F7162.jpg[/attachment]
Once the case is split, it’s lots easier to get at the rod bearing caps. I use an old serpentine belt to lift the crank out. No one likes a scratched crank shaft so cover the rod bolts when removing.
[attachment=46181]27719C2A-3A89-48CB-9321-FA22730D1A2E.jpg[/attachment]
Once the crank was out, I could get the semi stuck pistons out. Then I went ahead and took the gears off the starter and mag shafts, that way you can change the seals and if necessary the bushings in the timing cover. A simple steering wheel puller will get the gears off, but be aware the gears are tight on the shafts.
That does it for the tear down, now I’ll take it down to my machine shop and let them work their magic.
BP.
