The effect of lubricant on torque spec
Showing 1 to 10 of 15 results
TOGNOT
I finally got all my rollers installed on the bottom of my d6 with new CAT bolts and washers ( made in China....)
The torque spec is between 150 and 170 ft lb. I used a moly type assembly lube on the threads. It is my belief that using lubricant on the fastener (bolt) increases the installed stress on the bolt given the same amount of tightening torque.
Example : torque a lubricated bolt to 100 ft lbs. the stress on the bolt is - say - 75,000 psi
Now torque the same bolt with no lube to 100 ft lb. the stress on the bolt is 30,000 psi.
These numbers are just to make my point. And to lead to my question...... Must I consider the lube on my 9/16 NF carrier bolts when calculating a torque spec ? Assuming yes, who can suggest a torque spec based on the above info.?
Thanks - don't want to break a bolt or have one come loose!
Fri, Nov 3, 2017 4:39 AM
i really can't speculate on a dozer machinery spec--but i would surmise that it would not be dependent on the lubrication of the threads--every mechanic would be using a different lubricant and amount applied My experience is with structural steel applications--our spec called for a 30000 lb load on a 7/8 diameter A325 bolt. we would take a load cell test each morning and calibrate a torque wrench for the number of foot lbs to achieve this tensile load with no lubricants--the contractor would always use an air impact wrench. I would take my manual torque wrench and calibrate it also, and then would spot check the contractors installations.
As long as you stay below the ultimate tensile strength of the steel bolt and be in the yield strength range it shoudn't matter much where you are--
does this make sense?? OM--your opinion please!
Fri, Nov 3, 2017 5:03 AM
Thank you received: 19
Reply to dpendzic:
Use either one of these charts......
Fri, Nov 3, 2017 6:19 AM
mog5858
Reply to dpendzic:
well what little i know about this is there a 30% difference between lubed and non lubed. so if your looking for 100 ft/lb when lubed it only takes 70 ft/lb to get the same stretch. but this has been when working with BIG stuff 2"-4" range bolts which where most of the time studs in drag lines not bolts. the rule of thumb is it would be a dry torque unless it tell you lubed it. now i know what kind of lube will change things. this is onsite passed down info so consider that when making your decisions as i have never read up myself. i don't know if i answered your question or just made more points to question's .
Fri, Nov 3, 2017 6:33 AM
Reply to mog5858:
great tables! surprised at the big differential in the first table between lubricated and ant-seize
Fri, Nov 3, 2017 6:37 AM
TOGNOT
Reply to dpendzic:
Thanks all. I torqued them to 100 ft lb ( with lube) . I will run the machine for a few hours ( someday......)
And the have Oilslick crawl under there and recheck them.
Glad I axed that question!
Fri, Nov 3, 2017 8:04 AM
Reply to TOGNOT:
That seems low by either chart using lubed threads.
Fri, Nov 3, 2017 9:03 AM
ETD66SS
Send a private message to ETD66SS
The CAT hardware is made in China???
Fri, Nov 3, 2017 9:32 AM
Oil Slick
Reply to ETD66SS:
My Cummins manual shows to lubricate all the critical bolts and both sides of the washers.
I’ll look tomorrow and see the torque difference between lubed and dry same size bolts.
Fri, Nov 3, 2017 10:06 AM
ianoz
Reply to ETD66SS:
By the looks , not much they don't make in china .
http://www.caterpillar.com/nl/company/global-footprint/apd/china.html
Fri, Nov 3, 2017 10:12 AM
rmyram
i would have used nickel antiseize as the lube and dropped the tourque down about 20 % to about 120 to 130. or so.
Fri, Nov 3, 2017 11:55 AM
Price Tractor Pull
Price Tractor Pull
