Separating Berco track chains
Showing 1 to 10 of 10 results
Gregness
So the D2 went to the doctor for a few things this summer- Good news is the brakes are now adjusted and I have lots of pedal (Yes!) and the electric pony motor starter-generator set up is all dialed in. Bad news was my Cat guy could not get the tracks apart to work on the shot idler bushings. He tried heat, hammers and a hydraulic press but could not get the pin to back out. Any comments or ideas out there?
Greg
Fri, Sep 29, 2017 11:30 PM
Nothing unique about Berco master pin that I'm aware of. More beef and/or higher tonnage hydraulic press required.
Fri, Sep 29, 2017 11:40 PM
captainhowdy
Send a private message to captainhowdy
get a new pin from Berco then get a gouging rod and burn the center from your old pin. let it cool then drive it out with a hammer. when ur done install new pin.
Fri, Sep 29, 2017 11:46 PM
Thank you received: 11
Reply to captainhowdy:
Sometimes you can pull the front idler back enough to slip tracks off, have done that on D2, no top carrier rollers on it though.
Suggestion of burning and then driving is one have used many times. often cut an X in pin from both sides, but all we had was Oxy-Acet -- lots of blowback!
Make sure you have a solid backing when driving the pin out, took two of us - one holding a pin with channel locks and one swinging 16 Lb hammer.
Good Luck!
Sat, Sep 30, 2017 2:03 AM
Reply to ctsnowfighter:
Good Luck!
Gregness where are you located?
Sat, Sep 30, 2017 2:59 AM
Gregness
I am in Olympia Washington, machine is on our ranch north of Spokane. Burning out the pin and replacing is the direction we are headed, but if I could save the pin that would be preferable. I don't think my old Cat guy is familiar with Berco, maybe he did not find the master? Hopefully replacement pins will be available and not too dear...
G
Sat, Sep 30, 2017 3:31 AM
Thank you received: 7
I just put an order in for some new plugs for my master pins rather than going to the solid pins for my Cat rails. They were easy(ish) to get out once the plug was removed
Sat, Sep 30, 2017 5:25 AM
Reply to Gregness:
G
[quote="Gregness"]I am in Olympia Washington, machine is on our ranch north of Spokane. Burning out the pin and replacing is the direction we are headed, but if I could save the pin that would be preferable. I don't think my old Cat guy is familiar with Berco, maybe he did not find the master? Hopefully replacement pins will be available and not too dear...
G[/quote]
Oh ok, a little too much of a drive for me, lol, I could of pressed it out for ya.
Sat, Sep 30, 2017 6:33 AM
16 pound sledge is important.
Good driver setup so your holder is not endangered and you can swing like you mean it.
Put the master on the sprocket and back up to a square block so it has a corner under the grouser below the pin. This holds things securely
Finally, some heat on the rails around the pin.
I don't think a master is any smaller than a regular pin WHERE IT FITS INTO THE RAILS. Thought they were a little smaller the rest of the way through so they would move easier once you get it moved the first little bit. Maybe they are always worn a little (or a lot) where the bushing touches it instead of being made that way.
Sat, Sep 30, 2017 6:53 AM
catsilver
Its OK beating a pin to death but if the links 'spread' it will never come out, it is as important to hold something heavy against the back link like a 20lb sledge as it is to use something like a 14 pounder to drive it out. This is only a little machine so shouldn't take too much but its more important to support the back link than clamp the track down under the sprocket, this only supports the front link.
Sat, Sep 30, 2017 3:28 PM
I wonder how effective a jack hammer would be driving pins. I have heard people claim that a small air/impact hammer will easily drive small pins that are very hard with hammer and punch. Maybe the track pins would be the same way.......easier to rattle them out than drive them. Our local rental place used to have a pretty capable electric unit that wasn't too expensive rented for the half day. Sure would be something that most folks could easily access vs hiring someone with a hydraulic press.
Sat, Sep 30, 2017 6:55 PM
Veerkamp Open House 2025
| Placerville, CA
Stradsett Park Vintage Rally
Chapter 2 The Link Club's AGM
