Cat 15 weight ?
Cat 15 weight ?
Showing 1 to 6 of 6 results
pgill
Send a private message to pgill
I am looking at a modified Cat 15. It supposedly has a good set of D2 tracks that I could use. does anyone know about how much this will weigh? I need to figure out how big a trailer I will need. I'm guessing about 5-6 k lbs but I'm not sure.
Thanks,
P. Gill
[attachment=43978]cat 15.jpg[/attachment]
Fri, Aug 11, 2017 2:28 AM
Steve A
Looks like 5600 for a bare factory machine
http://www.chriscomachinery.com/15serial.htm
Will there be enough links for a D2, Might consider a set of D3 rails, will fit on a D2 after you tale out a few links.
Fri, Aug 11, 2017 8:26 AM
JDcat
Send a private message to JDcat
The small 7C Series 15 weighs 4480 lb. Track gauge 37 / 44 inch, and the big PV Series 15 weighs 5790 lb. With track gauge 40 / 50 inch.
Hope this helps,
John
Fri, Aug 11, 2017 8:29 AM
FatCAT
Send a private message to FatCAT
Reply to JDcat:
Hope this helps,
John
Looks like a PV 15 by the looks of the spring hangers
Good luck with it
Fri, Aug 11, 2017 10:22 AM
pgill
Reply to FatCAT:
Good luck with it
Thanks for the information guys.
My rails are worn out on my d2 and these look to be in good condition. The guy wants 500 for the machine so I will pick it up and take what I need. I'll post the rest of the machine for parts once I take what I need.
P. Gill
Sat, Aug 12, 2017 12:38 AM
MARCOTEN
Reply to pgill:
P. Gill
any more pics of this 15?? is it a Original engine?
Sun, Aug 13, 2017 4:02 AM
pgill
Reply to MARCOTEN:
It has a retrofitted Mazda diesel engine.
Sun, Aug 13, 2017 6:31 AM
