Hydraulic track adjuster question
Showing 1 to 10 of 17 results
Catboy1
Send a private message to Catboy1
Hey guys, I got a new machine! It an 8u. I don't have the serial number with me but it has been upgraded to hydraulic track adjusters. What is the procedure for adjustment? Does it work to just stick a grease gun on there and pump away? If that's the case there is something wrong with mine. I tried to adjust the right side track and the grease fitting moved towards the spring instead of the idler moving out. What am I doing wrong? I'll get some pictures next time I'm at it. Thanks, Robyn
Thu, Jul 20, 2017 9:39 AM
Andrew
Sounds like the recoil spring is being compressed rather than the idler moving.
The trick is to drive the machine back and forth after every 50 or so pumps .
It is rather dis heartening to spend ages pumping grease only to find the track too tight and having to let most of it out .
Thu, Jul 20, 2017 3:59 PM
Catboy1
Reply to Andrew:
Thanks for the reply Andrew. I did drive it back and forth a bit. I also put blocks under the blade and lifted the idlers off the ground, thinking there would be less pressure forcing them back. I think I'll take the spring cover off and take a look to see what's going on.
Thu, Jul 20, 2017 8:08 PM
Thank you received: 48
Reply to Catboy1:
One note of Caution -
Do NOT remove the grease zerk to relieve the pressure. It is a bullet waiting for release.
cts
Thu, Jul 20, 2017 8:16 PM
Reply to ctsnowfighter:
cts
I had an idler/adjuster do that and the idler had twisted a little from wear and locked into the frame--a little twisting with a bar and a light pull on it got it moving out again
Thu, Jul 20, 2017 8:38 PM
Catboy1
Reply to dpendzic:
Hey guys, I think I have figured out the track adjustment problem. It looks to me like the adjuster rod is bent causing the idler to be cockeyed in its slides, jamming it. Is it possible to get this rod straightened? Can I get it out without splitting the tracks? Here are some pics and a few of the new machine. I can't figure out how to turn my pics over. They looked normal in my computer. They were taken with an iPhone. Could one of the moderator please turn them the right way
[attachment=43706]IMG_2569.jpg[/attachment][attachment=43707]IMG_2568.jpg[/attachment][attachment=43708]IMG_2567.jpg[/attachment][attachment=43709]IMG_2566.jpg[/attachment][attachment=43710]IMG_2565.jpg[/attachment][attachment=43711]IMG_2564.jpg[/attachment][attachment=43712]IMG_2563.jpg[/attachment][attachment=43713]IMG_2562.jpg[/attachment][attachment=43715]IMG_2560.jpg[/attachment][attachment=43714]IMG_2561.jpg[/attachment]
Tue, Jul 25, 2017 11:32 PM
seiscat
Reply to Catboy1:
[attachment=43716]IMG_2569.jpg[/attachment] [attachment=43717]IMG_2568.jpg[/attachment] [attachment=43718]IMG_2567.jpg[/attachment] [attachment=43719]IMG_2566.jpg[/attachment]
[attachment=43720]IMG_2565.jpg[/attachment] [attachment=43721]IMG_2564.jpg[/attachment] [attachment=43722]IMG_2563.jpg[/attachment] [attachment=43723]IMG_2562.jpg[/attachment]
[attachment=43724]IMG_2561.jpg[/attachment] [attachment=43725]IMG_2560.jpg[/attachment]
The upload was acting up so this post might have been edited as I was doing this.
Craig
Wed, Jul 26, 2017 12:16 AM
mrsmackpaul
Reply to seiscat:
Craig
I dont think the rod is bent I think the guid it is meant to slide thru is part missing as in rusted off, it looks that way in the photo maybe just covered with dirt and the bolts have come out
The bracket stops the rod from lifting and and lifting and twisting the idler yoke as it has done
Maybe have a scratch around with with a smallish crow bar type thing o and scrape all the dirt off to see whats happened, perhaps clean the other side as well because it is most probably still all there and it will show you what you are chasing
Once you work out if its missing or the bolts have worn thru or are missing you will need to back the adjuster out and either stick a bar in the teeth on the sprocket and drive the machine to pull the idler or drive it up slowly on to a suitable stump or chain block it back to get the rod and yoke to sit back down flat so they can be clamped
Paul
Wed, Jul 26, 2017 2:26 AM
Reply to mrsmackpaul:
Paul
as Paul said, there appears to be a Guide Assembly partly missing--rusted away. It is also a SAFETY Support for the Equalizer Spring end to rub and react upon when the front of the machine rears up and tries to carry the track frame--usually occurs when forcing a hyd. blade down and lifting the nose of the machine.
P/No for the older screw type adjuster type was 7B5485 but may well be the same P/No for the two styles of Hyd. adjuster, maybe someone that has a later P/Book to mine can help out.
DANGER :- also of Note is the Zerk mentioned that is in the Early style Relief/Adjuster screw that MUST NOT be Removed as it does not relieve the adjuster grease pressure and will eject at high velocity.
These are Special Zerks that have the ball check down inside the zerk body--cheap zerks have the ball check visible at the connector end and these tiny balls have been known to fly out, when sufficiently pressurized, with fatal results.
After this the relief valves were modified to have no removable zerk as they were machined in one piece.
Wed, Jul 26, 2017 7:40 AM
Catboy1
Reply to edb:
I am wondering if mine got cut off when the hydraulic adjuster conversion was done. I can't see any place it would be when I scrape the dirt away. There isn't one on the other side either. I'm going to pressure wash it tomorrow to be able to see better. On the 977 loader it looks like the hardbar is doing that job. Does anyone have a picture so I can try making one and welding it on or is it not a part that can be easily made? Thanks for all the responses, Robyn.
Wed, Jul 26, 2017 12:32 PM
Thank you received: 19
Reply to Catboy1:
Yes, get it cleaned up so we can see what's going on. Clearer pictures would also help.
From what I can tell those are after market hydraulic adjusters. Looking at that two bolt clamp on the push rod I'd say they haven't worked in some time. Also looks like the idler push rod is bent.
Wed, Jul 26, 2017 11:08 PM
Price Tractor Pull
Price Tractor Pull
