Surprised you haven't broken an armature shaft with all that torque. Straight tooth flywheel on that grader?
Why do you have this ? I'm guessing you turn the motor with it - but not start it. Right?
Ingenious. A great use for a bad starter. Nice thing is that if it broke it would be the armature and not the flywheel tooth.
well that wasnt what I expected to see when I read the heading
What a great idea
Paul
So the purpose is to get a mechanical advantage to break loose a stuck motor ?
No one else is asking but I doubt I'm the only one who has not seen it before..
thanks guys. 30 years ago i tried to free up a seized motor and in the end i hurt my self and broke a tooth on the flywheel by stilling a bar in the hole and prying. while i was at the hospital getting stitches i came up witht he idea of the bar starter. there are teeth to teeth and everything is centre when applying the power to break the engine free. i never thought my welds would hold on the armature because of the copper effecting the welds but 30 years later the welds are still in good shape.
old magnet -- the motor is a UD-16 which is very different work on because things are just alittle different from a td-9 and td-18. the flywheel is a straight tooth.
as of sunday night the heads are back on the engine and ready to be test fired once the gasket goo is dried.
thansk
KoO
Published Author
there is a page on my website for the bar starter.
http://kingofobsolete.ca/KING'S_BAR_STARTER_WEBPAGE.html
thansk
KoO
Published Author![]()
I wouldn't have given that much of a chance of working if I had seen it when you were building it with the copper contamination in that weld. Maybe it makes it better? You did something right on it.
