curious about track loader
Showing 1 to 9 of 9 results
Riverina d4
Send a private message to Riverina d4
.Mostly only see the rubber tracks fitted around here.I wonder what the measurements of those rails are.
100 plus hp the top end of the range I'm told,do they get the power to the ground better then the rubber track?
Fri, Jun 16, 2017 10:43 PM
Bruce P
I'm no where near an expert, but I'm told that they like steel tracks better when these go to the woods. They equip them with front mounted shredders for brush clearing work.
Just what I've been told, could be totally wrong.
BP.
Fri, Jun 16, 2017 11:56 PM
Thank you received: 23
Reply to Bruce P:
BP.
How does one adjust the chain tension on that rig?
Sat, Jun 17, 2017 4:22 AM
I'd guess hydraulic adjuster on the front idler, just like the big boys.
Sat, Jun 17, 2017 4:37 AM
dtcohen
Send a private message to dtcohen
There is a grease cylinder/ recoil assembly. A grease gun is used to pump grease into the cylinder to set the track tension
Sun, Jun 18, 2017 10:05 AM
dtcohen
[quote="Riverina d4"].Mostly only see the rubber tracks fitted around here.I wonder what the measurements of those rails are.
100 plus hp the top end of the range I'm told,do they get the power to the ground better then the rubber track?[/quote]
The steel track machines are used in mulching applications. Unless you are doing that type of work they are probably overkill. You also lose the 2spd option with the steel tracks.
Sun, Jun 18, 2017 10:10 AM
Riverina d4
Reply to dtcohen:
ok,that would be a deal breaker loosing the two speed option so thanks for the input.What sort of hours do they get out of steel tracks?.At 100hp I assume they would spin the track easy enough!
Sun, Jun 18, 2017 3:56 PM
Reply to Riverina d4:
Makes sense - I couldn't see any movable parts from that photo angle.
Sun, Jun 18, 2017 8:27 PM
Tracklayer
Send a private message to Tracklayer
I suspect that steel tracks will gain in popularity just as full-time undercarriage rubber tracks became preferred to the over-the-tire tracks on skidsteers. What is the cost of this steel track system compared to a rubber track system? I wonder how the total life costs of steel tracks compare to rubber tracks. Might the steel tracks actually be less costly on that basis?
One benefit of rubber tracks is that they cause less damage to finished surfaces. This is very important to some users, but the more robust, longer life of steel tracks may be a more important attribute to other users.
It is interesting that this compact “Traxcavator” has come about by upward evolution of the skidsteer rather than downsizing the larger steel track loaders.
Sun, Jun 18, 2017 9:28 PM
The lack of two-speed could just be a different valve or some kind of lockout - manufacturers like parts commonality
Sun, Jun 18, 2017 10:24 PM
