Rustolleum paint job?
d2gary
I was researching something to do with my jd410 when I ran across a forum with instructions (I will use the term instructions very loosely) on how to paint a tractor with industrial rustolleum enamel. It went something like this,
Go to Wal-Mart and get the $28 a gallon paint, then to the automotive paint store and get some enamel hardener, any old kind will do. A gallon of enamel reducer.
Mix the paint and reducer at 1:1 ratio and some hardener
No need to measure just put some in. Spray it on and its perfect every time.
I'm not an expert painter but have painted a few cars and plenty of trailers. This sounds a little sketchy to me. I have little experience with enamel paint but it seems like the mixing of different brands of materials and the unscientific mix ratios could spell disaster.
Does anyone have any experience with this sort of thing?
Paint is a ways off for me but I like to be informed before I get to that point.
I will add that it sounds like the paint in question was designed as a brush on application.
There was some photos of some painted tractors and such, who knows if it was the magic rustolleum paint or something else. The pictures presented looked good, but it is the internet!
Tue, Jun 6, 2017 10:03 PM
STEPHEN
Without endorsing the formula, I have found paints for brushing and high solids paint will tolerate or require more reducer to be sprayable with my harbor freight gun. I have used paint out of the can that was easy to run without any thinning. Yellow seems to have poor hiding power, so I use a yellow primer when I can.
Tue, Jun 6, 2017 10:28 PM
Have seen the use of hardener in enamel. It was JD green from the dealer. Friend of mine added the hardener and it turned out with a nice shine. Still looking good about 10 years in.
Wed, Jun 7, 2017 5:24 AM
terrywelch_archive
I have been painting vehicles including, cars, tractors and trucks for 40+ years. The type and brand of paint you use is up to you. The suns rays will fade the paint. A automotive grade paint will hold up longest for this and a WalMart brand will start fading within a year. Using Hardner will help a lot. Not all brands of hardner will work with all paint. I try a little of each in a Dixie cup to make sure it does not turn to "cottage cheese. If not you are good to go. Normally the brand they sell at Tractor Supply works with most. Also remember the hardner is not good to breath in so wear approved mask.
As for reduction go by the label direction. Normally the lower cost store brands are a 10-15% reduction. Automotive style paint is different and some use little to no reduction at all.
Best thing is to follow the label. Then you start with a good foundation.
Hope this helps
Terry
Wed, Jun 7, 2017 6:24 AM
Reply to terrywelch_archive:
Hope this helps
Terry
Haven't used the new stuff yet!
At Tractor Supply you can buy the brand Terry is referencing. Also on the shelf is a pint can of reducer that you mix with a gallon. There is also a Hardner which it states will make it shine and not sun fade as quick. I bought a gallon for a John Deere project that hopefully will get sprayed yet this year. I didn't buy the Hardner as I am not a professional painter and am afraid it will harden before I get through it all.
Terry has good knowledge in paint as he used to do body work and painting!
Back in my youth we painted lots of Farm Machinery and Farm trucks with Rustoleum. We used to thin it with the Fish Oil Thinner that Rustoleum sold. Since they EPA forced changed their paint formula I don't believe its as good as the OLD paint.
Wed, Jun 7, 2017 9:33 AM
d2gary
Reply to drujinin:
Thanks for all the tips, very helpful.
I don't have enough experience to start mixing and matching materials and making custom blends.
I think buying everything from one supplier and following their instructions is sound advice.
From my past experience with the cars I've done the prep work that nobody sees is 95% of the job.
Wed, Jun 7, 2017 9:27 PM
