D6 9U steering pump seals
Showing 1 to 10 of 31 results
TOGNOT
When searching through old posts I could not find what I'm sure I have seen before: a photo or drawing of a "tool" to remove and replace the seals on the steering booster pump.
My pump is leaking and I'd like to seal that up before installing the fuel tank. My HOPE is I can put new seal in while leaving the pump on top of the trans???? I'm fairly confident the reality is not that easy a solution.
If any one can direct me to the "rebuild a pump" link, that will get me started.
Thanks!
Fri, Jun 2, 2017 9:04 AM
Impossible. At least if you mean the pump shaft seal that leaks the oil from the steering booster into the bevel gear housing.
You are correct, time to do it now while the seat tank is off. You unbolt the steering booster unit and flip it over to remove the pump from the bottom. Then you pull the shaft and replace the seal. If you have leaks from the front plungers or output quills that sit down on the steering clutch release shafts, this would be the time to do those as well. Just the booster pump shaft seal will take maybe a couple hours at most.
Fri, Jun 2, 2017 10:58 AM
Thank you received: 39
Pulling booster seals. 7/8" x 14 tpi threaded rod and coupling.
Fri, Jun 2, 2017 12:30 PM
TOGNOT
Just what I wanted - thank you. Of course no way to know the condition of the seals INSIDE the unit, but I can see the seals on the outside leaking. The unit (pump) does not lose oil quickly, I am hopeful only the outsides are leaking.
Who knows, maybe I'll be overcome with ambition and pull it just for fun.
Thanks again
Sat, Jun 3, 2017 2:46 AM
Andrew
Reply to TOGNOT:
Thanks again
These booster units are no big deal to remove and replace.
The pump shaft seals should be replaced . It will leak oil from the booster into the bevel gear compartment which shares the oil with the gear box.
Can be happening and you dont even know.
Pump shaft seals are back to back ;ie inside seal keeps oil in booster , outer keeps oil in bevel gear compartment. I think there is room for two seals facing each way. Seal are standard of the shelf and only cost a few dollars each.
There is also a filter screen in there that should be cleaned while you are in there.
Sat, Jun 3, 2017 4:12 AM
TOGNOT
Reply to Andrew:
Dang, you guys never cut me any slack. I won't have any reason to work on it next year if I fix it right this year....
Sat, Jun 3, 2017 11:31 AM
Thank you received: 58
Reply to TOGNOT:
Haha - famous last words : )
Sat, Jun 3, 2017 7:24 PM
7upuller
Reply to TOGNOT:
Keep taking advice from OilSlick... he usually fixes things 3-5 times before getting it right. :doh: That way you can fix it next year and the year after...👍
Sat, Jun 3, 2017 8:03 PM
TOGNOT
Reply to 7upuller:
Ok, I pulled the light weight steering booster off the D6 and brought it into the shop. Maybe if I had left it in the sun, where it is to reach 110 today, it would come apart easier.
I saw all the extreme weather warnings on the news so I took a break, and their advice, to enjoy an adult beverage while I ask another question.
I drilled out the pins on the top of the booster, until I hit aluminum - about 3/8" deep. I built a seal puller
With a piece of all thread and a ground down nut. I used a jamb nut to hold the "puller nut" in place.
I threaded the puller onto the seal ( ok, seal holder). I believe I have about3/8" thread engagement. Then with a couple washers I tightened down the puller nut to extract the seal holder. No movement.
I'm not real comfortable putting a lot of torque on something that, if it breaks, I'm screwed.
A little heat maybe ?
Thanks all
Tue, Jun 20, 2017 3:37 AM
Reply to TOGNOT:
Thanks all
Having to drill out the pins is a left over piece of miss- information. Those pins retain the seat/retainer, not the seal holders.
3/8" - 1/2" thread engagement is about right. Shouldn't have to heat but I don't see why not if you wish.
The picture shows about where the holders are located.
Tue, Jun 20, 2017 4:08 AM
TOGNOT
Thought I was being proactive by searching old posts and came across the " drill out the pin" thing. SO now, I'll tap those hole and install a couple set screws...
Seriously, I think I'll set it out in the sun for a couple hours. I'm sure it will get up to 150 degrees or so.
Any harm tapping on the "puller" lightly to knock the seal holders loose ? Or do they sit bottomed out inside the case ?
Thanks as always!:loco:
Tue, Jun 20, 2017 4:41 AM
