D7 3T Electric start
7 years 6 months ago #165232
by texaspatd73t
Bought a 24 volt starter for D7 3T4731 and it doesn't look like teeth are engaging enough.
Does anyone know what the proper nose gear is ??
7 years 6 months ago #165258
by keloz
hi there how are you? check you have the right pinioni got one off ebay asked for right hand helix was sent a left didnt check put it on loooked just like yours when i pulled it out kelvin
Thank you received: 821
7 years 6 months ago #165289
That is a RH helix pinion. How many teeth does it have?
Normally requires an adapter plate to mount to the 3T and the hole needs to be aligned correctly to get proper engagement clearance. Looks to me like you don't have proper clearance. Buggered up ring gear teeth is going to make it that much more difficult. How about some pictures of the rest of your installation?
7 years 6 months ago #165333
by texaspatd73t
Have what looks to be same starter as you show in attachment. Will get a tooth count and more pictures today. When I installed three bolt holes already there, just bolted on starter. Not sure if any way to adjust?
Is there a way to adjust how far the pinion extends?? Could it be not coming out far enough?? All help appreciated. Started fine until pony gave up, thought the electric start a better route than rebuilding pony.
7 years 6 months ago #165337
If this was a conversion starter set up for the 3T then I'd say there is a problem with centering of the starter on the adapter. This would depend on the machining and no, there is no adjustment for centering. Time to talk to the supplier.
As far as checking the pinion extension which does have slight adjustment, this is what it should be set for.
7 years 6 months ago #165368
To meet standard SAE mounting requirements the distance from the drive end housing face of the mounting flange to the face of the flywheel should be two inches. The flywheel engagement dimension for the pinion is 7/8".
7 years 6 months ago #165380
Those are good pictures.
That looks sorta right!! but that doesn't mean it's machined right.
Pull the solenoid mount/cover off and work the plunger by hand to see if it properly extends the pinion. (on the bench).
Is that one of "Auto-Lec's" conversions?
Thank you received: 345
7 years 6 months ago #165428
by edb
is it my tired eyes or the way the pic of the flywheel teeth is taken that those teeth appear to be straight cut.
I stand to be corrected.
7 years 6 months ago #165430
by mrsmackpaul
Could this be done with it bolted onto the crawler and look thru that big bung hole on the top of bell housing above the pinion ????
If so you could see for sure that it is either engaging or not
I dunno if you could see past the end of the starter motor or not but might be worth a try
Paul
Time to create page: 0.201 seconds
