That's a nice looking tractor. It looks like it's ready to go to work.
I like it, but looks like like the sprockets were replaced with used ones.
I am just guessing but i think the sprockets,pins and bushings have about 400 hours on them since rebuild. i am pretty sure the owner didn't replace any rollers either but not sure. the rollers are all grease able type. where can i get the end for my grease gun so i can service them? what type of grease should i use?
Good looking machine!
I gotta get a button head grease gun for my rollers. is this the one? https://www.mcmaster.com/#button-head-grease-gun-fittings/=17rjnk4
yes get 7/8" one. do u have the lube pump and know what to use in it?
[img]https://s26.postimg.org/oa2ajlvzd/SAM_0212_zps3ujfwhqo.jpg[/img]
Thanks Mike!! I have an Alamite grease pump but we used it to fill guns with NO 2. my thought was to get the correct fitting and use corn head grease from Deere because i can get it in tubes.
ok, just use the right stuff according to the operators and instruction book. i find lube chart right on except its agreed that atf be used in starting pinion clutch housing.
