Paccar Engines
Paccar Engines
Oil Slick
Looking at a used truck with a Paccar engine. How you all feel about Paccar diesel engines in trucks with def?
Fri, May 19, 2017 10:35 AM
7upuller
Hey Mike,
I've heard a lot of bad on the Paccars, unless it's the Px-9. That's the only one that's cutting it.
Fri, May 19, 2017 9:20 PM
ironman3406
Chapter Twenty Seven
Send a private message to ironman3406
Reply to 7upuller:
Hey Mike,
I used to work for Peterbilt and I was sent down to the factory in Denton Texas for training on the Paccar engines. I was not impressed with the engine from a technician point of view. For starters everything is rear gear train meaning the air compressor, power steering pump, timing gears, etc are all at the back of the engine. If you ever have to do any kind of camshaft work you have to pull the engine out. A cat or cummins you are able to do it through the front. The main bearing caps are impact fractured, if one is ever put on the wrong mate during overhaul and the fracture line is damaged, you have to replace the block. The electrical harnesses are not serviceable they are a foam filled harness that you cannot easily cut into and make repairs you have to replace the harness. Those were the things I disliked most about the engines as a technician, the final thing I hated up here in canada wasn't the DEF does not like cold and we saw lots of issue with the emissions system. I'd stick with a cat or Detroit if you can find.
Cheers Nate
Sat, May 20, 2017 2:23 AM
WyoCat
Reply to ironman3406:
Cheers Nate
The PX-9 is the Cummins ISC, painted gray with paccar badges, that probably explains why it has such a good reputation. As for the rest of them they are real hit or miss. Fuel economy is way down. There is a guy here locally that loves his MX 13 liter. No problems this far. Has 340K on it. Hard to compare the 13ltr paccar to a 15ltr ISX.
Chad Enyeart
Sat, May 20, 2017 3:22 AM
hiwide 15
Send a private message to hiwide 15
Reply to WyoCat:
In my opinion only the isx is ok till overhUl time then trouble starts the blocks have to be cut down under the liner's and shimmed up to bring the liner's up to spec and the I have seen three of these pull the liner out of shape a d seize with only few thousand miles on them. Not like the old days, usually breaks the block and you are done, buy old cat And smile
Sat, May 20, 2017 8:57 AM
Oil Slick
Reply to hiwide 15:
My neighbor has a 2001 W900 with a Detroit 60 series. Has 1,200,000 miles with no engine repairs. But the only way to get a Detroit now days is to buy a Freightliner. I can't see myself buying a Freightliner. 2012 and newer KW's have def fluid so they can be ran after 2020. But KW only offer the ISX or Paccar.
Pops, what engine you have in your new Pete's?
Sat, May 20, 2017 11:20 AM
