Its good to see an American Company leading out front.
Yes, but ...
LeTourneau used diesel-electric power (similar to a railroad locomotive) 50 to 60 years ago in his earthmoving equipment. Good to see Cat trying to catch up.
Cats Forever
Right on George, Railroad Locomotives have been doing this for decades!! 😊
Heh heh .. the funny part about this "new development" .. is that Cat pooh-poohed electric drive for decades as a waste of good copper .. and went to town, on opposition manufacturers, such as R.G. LeTourneau .. pointing out all the terrible maintenance problems and drawbacks of the LeTourneau electrics .. when R.G. had excellent performance wheel motors, and electric motors driving winches on the Tournapulls, by the late 1940's .. after having built his first electric drive scraper in 1922!
My, how the worm turns! Diesel electric drive is a proven concept, it has been around for over 90 years (Porsche built the 1st gasoline/electric drive car in 1901!) .. and it has massive potential, that Cat have apparently, only just discovered .. 🙄
LeTourneau museum pics .. http://www.letu.edu/about_LU/museum/Museum_Online/the_machines/page_1.html
OzDozer, thanks for the link. I looked at it. The photographs were very clear. LeTourneau also wrote an autobiography. I need to buy it. Anyone can find it from time to time as an out of print used book at www.bookfinder.com. GWH
George - The book, "Moving Heaven and Earth", by Donald F. Ackland, is R.G. LeTourneau's autobiography, and a great read about a man who stands out as giant in the equipment industry. The book is readily available .. I use .. http://biblio.com .. to source a lot of my books .. and there are currently 34 copies available .. 😊
http://www.biblio.com/search.php?author=Ackland&title=Moving+Heaven+and+Earth&keyisbn=&format=any&stage=1
Another couple of worthy LeTourneau books, are the books by local LeTourneau expert, Phil Gowenlock .. LeTourneau Legend and the LeTourneau Archive. The first is the most comprehensive history of LeTourneau and his manufacturing output, that you will find .. the second is purely a book of full page classic LeTourneau archive photos, of virtually all of his machines.
Tournanet site books .. http://www.tournanet.com/books.htm
The LeTourneau Legend .. http://www.biblio.com/search.php?author=Gowenlock&title=LeTourneau&keyisbn=&format=any&stage=1
Regards - Ron ..
My thanks to OzDozer for his information! Very complete. GWH
Back in the 1960s I believe it was this R.R. Co up in Sayre Pa. sent several of the old Cat D17000 V-8 engines down to the shop that I rebuilt for them. They said there was two of the engines in one locomotive and I believe they said they were switcher locomotives that they were in. They powered a big generator in the locomotive. THe D17000 was about like the old 2U D8 engine as far as bore and stroke and with the outside tubes for the push rods.They had a single head for each cylinder and was a 90 degree block and also there were 4 blocks on them where the liners set in and the lower crankcase was a separate casting as the top blocks bolted to the lower crankcase block.They were a little different from the normal engine that Cat made at that time.The regular engine had a starting engine across the back like a D2,4,& 6 but was bigger.Those engines in the locomotives didn,t have a starting engine on them but motorized the generator some how to start them they said.
Hi SJ,
Since your on the topic of the D17000, I have a question for you on the pony engine they used. I guess you could say they were the Cadillac of pony engines as they had a water pump, oil pump and dual cam for the valves. I understand the early models also used tapered roller bearings outboard on the crank but were changed to the aluminum type on later editions. My question is about the tapered roller bearings and whether you recall there being any problem with them that led to the change.....or was it bean counters again🙄
Always thought it would be kind of neat to put taper roller bearings in the D2,4,6 ponies and have decent control of thrust instead of that Mickey Mouse pin arrangement.
