What are differences between a 112 grader and a 12E grader?
Showing 1 to 10 of 12 results
ETD66SS
Send a private message to ETD66SS
I've been looking at old graders, trying to find something pretty cheap, in the $3000-$4000 range on craigslist.
I'm coming across units like a Cat 112, 12E, Galion 118, Allis Chalmers D and a Huber's.
The 12E's seem to be a lot more expensive than the 112's, but I am not sure about the differences, sizes of machines, years made, electric start etc.
I'd like to find something like this: https://albany.craigslist.org/hvo/6056594216.html
Are 112's from the 1960's or are they older machines? Maybe someone can't point me to online resources to compare models/engines etc?
I want a grader to build and maintain a couple of long stone driveways, and future paths/roadways on my land. Maybe even snow removal? Not sure how well they work for that...
Fri, May 5, 2017 7:52 PM
Thank you received: 31
Hi, ETD66SS.
Basically, the 112 is 4-cylinder engined version of the 12 - D4 engine in the 112 as opposed to a D6 engine in the 12. The 112 are still a good grader, just not with quite the same grunt as the 12s.
The Galion 118s were a good grader too and about the same size as the 12s but would be a fair bit cheaper. What's more, the Galion 118s were all hydraulic controls as opposed to the Cat gear control system. The Cats might be easier to find parts for though.
Hope this helps.
Fri, May 5, 2017 8:39 PM
ETD66SS
Hi, ETD66SS.
Hope this helps.
[quote="Deas Plant."]Hi, ETD66SS.
Hope this helps.
Just my 0.02.[/quote]
Ok thanks.
Are the 112's and the 12's the same vintage, or are we talking decades apart in terms of manufacture date? Do both the 112 and 12 have gear control systems?
Fri, May 5, 2017 10:15 PM
Reply to ETD66SS:
Hope this helps.
Ok thanks.
112's and 12's ran pretty much production parallels all along with the 112F (89J) in 1974 being the end of 112 production. Full hydraulic controls did not come in until 12G (61M) models in 1974.
Fri, May 5, 2017 11:08 PM
Hi, ETD66SS.
Both the 112 and the 12 had gear controls up until the F series when they both went hydraulic assisted - which were MUCH nicer to use but try to find one in your price bracket.
Hope this helps.
Sat, May 6, 2017 12:52 AM
JDcat
Send a private message to JDcat
Hi, ETD66SS.
Hope this helps.
H.P. for No. 112 grader was 75, and No. 12, 100. Shipping weight for 112 was 19,880, and the 12 was 22,055. Figures were taken from Caterpillar catalog/brochure FORM NO. 717-31038-E-495.
John
Sat, May 6, 2017 2:27 AM
ETD66SS
Reply to JDcat:
John
Interesting, thanks for all the replies. While I would certainly like HYD controls on everything, maybe it's not a big deal to have gear controls due to how I would use the machine.
I've never operated one, so will be a total newb if I ever get one, just like I was with all my other equipment I suppose...
Sat, May 6, 2017 3:29 AM
Reply to ETD66SS:
Hi, ETD66SS.
This thread might give you some idea of controls and maintenance on the older Cat graders.
http://www.acmoc.org/bb/showthread.php?20409-Cat-12-Graders-Pre-G-series
Hope this helps.
Sat, May 6, 2017 4:35 AM
Paso Bob
Hi, ETD66SS.
Hope this helps.
I purchased a 12E 6 months ago and it is a good machine with a ballsy engine. It surprises me how much dirt it will move. The gear controls will make you work harder getting the job done than hydraulic. For me that didn't matter as I will probably only use it 30 hours per year. Purchase price mattered though, so hydraulic was out of the picture.
Sat, May 6, 2017 12:02 PM
7upuller
Reply to Paso Bob:
Hey PasoBob,
I know a guy that says hydraulic machines are just used for dust control. When the hoses break and cylinders leak, it keeps the dust down. In the long run, with limited use, the old gear style graders will just keep a going on if treated right. On hydraulic machines, once the hydraulics die, machines usually just get scrapped as it gets expensive to rebuild them. For limited use, nothing wrong at all with a 12 or 112 grader...heck I'm happy with my $864 Cat 12 80c. :high5:
Glen
Sat, May 6, 2017 12:25 PM
ETD66SS
Reply to 7upuller:
Hey PasoBob,
Glen
So, does anyone know about Huber graders? I have this one listed near me: https://buffalo.craigslist.org/hvd/6105638673.html
Wed, May 10, 2017 7:07 PM
Newby Hall Tractor Fest
