D6D guidance and opinions, considering purchasing
Showing 1 to 10 of 11 results
Kwright
Send a private message to Kwright
I'm shopping for a D6 machine, my previous post was for a D6C however I've located a D6D that I'm considering.
I appreciate any information or experiences with the D6D.
Thanks[attachment=41163]IMG_2873.JPG[/attachment][attachment=41164]IMG_2874.JPG[/attachment][attachment=41165]IMG_2875.JPG[/attachment]
Wed, Apr 5, 2017 12:27 PM
7upuller
KwRight,
I was looking at some Cats in a sale that had a D6d in the line up with a veteran Cat mechanic. He commented that the D6d was the worst tractor to work on in his opinion. He just hated a D model. I had to giggle as I responded that the D6d was one my worst models to operate. I personally hated running a D6d. It just wasn't a well balanced Cat in my opinion. Oh, it got the work done, and I have a lot of hours on one, but there are better balanced Cats to choose from. It was just funny hearing that a mechanic felt the same about the D model.
Glen
Wed, Apr 5, 2017 1:00 PM
Wombat
Donor
Reply to 7upuller:
KwRight,
Glen
I had a D6D 31X,my observations are, was ill balanced until I removed the Cat rippers and fitted it with heavy duty Milano rippers, after that it had good balance and a proper tractor. I never noticed it was any harder to work on than any others. I had one lazy operator and when he got near it, it would carbon up from too much idling, just have to be prepared to work them. Fitted a second set of lift ram balls, lower on the back of blade, when land clearing gave a lot more lift, equalizer bars could be a problem from fatigue.
Wed, Apr 5, 2017 2:01 PM
Kwright
Reply to 7upuller:
KwRight,
Glen
[quote="7upuller"]KwRight,
Glen[/quote]
What would be a better balanced CAT in the $20,000 range to use on a farm?
Thu, Apr 6, 2017 8:09 AM
captainhowdy
Send a private message to captainhowdy
Reply to Kwright:
Glen[/quote]
I owned and operated a D6D,a 4X model. it looked just like the one you have in the pics. mine had a winch on the back and that balanced it out very good. i ran one for a while that was bare back and i agree the balance wasn't good. i had problems with the tractor getting very hot and would run at the red line on the temp gauge after about 6 hours of constant operation on a 100 degree day. i had to replace the pinion gear on the transmission after about 6000 hours and i think that is a weak spot on that year model too.
Thu, Apr 6, 2017 9:45 AM
old-iron-habit
Reply to Kwright:
Glen[/quote]
If you are a mere mortal in the cat skinning world like most of us, you will probably never run it enough hours to notice the balance difference on a farm Cat. These guys talking balance were born wearing Cat seat material for diapers and got many thousands of hours in the seat. Just my humble opinion. :music::music::music:
Thu, Apr 6, 2017 9:48 AM
Thank you received: 31
Reply to old-iron-habit:
Hi, Kwright.
It depends pretty much on what you want it for. If it is for earthwork dozing, even if you aren't an experienced operator, you may just eventually figure out that a bare-a**ed D6D is OUTA BALANCE - - - and never mind O-I-H 'cos he cain't even keep a Steel Mule on its feet. In fact, he BROKE his neck to roll it over. LOL.
A decent ripper or a logging winch on the back end makes a different machine of them.
If you are going to be doing mostly clearing or drawbar work, the balance may not be such an issue.
Azfer working on them with wrenches, I dunno 'cos I have never had to do any of it.
Thu, Apr 6, 2017 10:12 AM
7upuller
Hi, Kwright.
KwRight,
I'd spend time looking for a good D6-c 10k model. Find one with a good undercarriage on it.
Glen
Thu, Apr 6, 2017 11:08 AM
Reply to 7upuller:
KwRight,
Glen
The D's couldn't be all that bad, they built/sold over 10,000 4Xxxxx power shifts alone. Bare tractor is a couple thousand lbs heavier and 140 hp 3306T vs the C at 125 hp. Is possible they pushed the hp a bit.
Thu, Apr 6, 2017 10:39 PM
rturn3060
Send a private message to rturn3060
Our company had two D's which gave good service and were no more difficult to work on than a C, but consider that C models are mostly in their 50's and D's in their 40's. Part availability is going to become an issue. As far as balance all dozers need something on the back, rippers being more use full for dozer work. Don't know about Glen's balance problem, maybe it is due to his rust affliction.
Thu, Apr 6, 2017 11:19 PM
Wombat
Donor
Reply to rturn3060:
D6C production ran through 1963 to 1977, 120hp, 125hp & 140hp models with DD or PS
D6D production ran through 1977 to 1986, 140hp DD or PS, also some special production 160hp long frame tractors DD or PS.
There were also ag tractor and LGP models as well as above.
Fri, Apr 7, 2017 4:49 AM
Newby Hall Tractor Fest
