Alternator drive
Alternator drive
Showing 1 to 10 of 17 results
Norm R2,22
Send a private message to Norm R2,22
I started a project to put a 12 v alternator on my D47U. I took the generator apart and will use the gear, front plate etc. as is. The body is a section of 4" scheduled 40 pipe. The rear plate is made from the disc brake off a 85 Chevette. I could have made it fron a piece of 3/8" plate but the disc was easier to mount in the lathe.
The first picture is of the gear, front plate and new shaft. [attachment=40986]alt drive 1.jpg[/attachment]
The second is the rear plate with a new bearing. I used a JD mower spindle bearing 3/4" ID. [attachment=40987]alt drive 2.jpg[/attachment]
The third picture shows the stud holes from the disc brake will line up with the thru-bolts that will hold everything together. I'll fill in the unused holes.[attachment=40988]alt drive 5.jpg[/attachment]
Tue, Mar 28, 2017 3:25 AM
64farmboy
Ah!! Good old american ingenuity!! Good jobl
Regards Dennie
Tue, Mar 28, 2017 5:26 AM
olfolks
Send a private message to olfolks
Reply to 64farmboy:
Regards Dennie
Norm, I am very interested in your project have thought of doing something like that before for my d73t would love to see more pic as you finish this up . great looking job so far thanks, steve
Wed, Mar 29, 2017 1:43 AM
Reply to olfolks:
Norm, I want to "Thank You" for thinking out of the Box another excuse for me to use when the Wife starts complaining about my "Miscellaneous Treasure Piles"! 😆 👍
Thu, Mar 30, 2017 12:05 AM
Paso Bob
Reply to drujinin:
I don't possess the talents or have the tooling you have Norm so I bought a complete unit ready made from Florin Tractor in Sacramento, CA
Thu, Mar 30, 2017 10:43 AM
Norm R2,22
Reply to Paso Bob:
Just up dating some pictures.
The first shows the shaft on the back end of the drive. The second shows the belt pulley mounted. The last shows a bit of extra shaft if I want to drive something else.
Mon, Apr 3, 2017 3:34 AM
olfolks
Reply to Norm R2,22:
looking good it took a turn I didn't expect LOL with the pulley I was thinking of mounting the alt on the end with a coupling but your project did give me some new ideas thanks very much for your time and pic's
Mon, Apr 3, 2017 9:25 PM
Thank you received: 24
Reply to olfolks:
Hi Norm, next time you come to Rochester, I'll take the remainder of the generator off your hands.
Mon, Apr 3, 2017 11:10 PM
Hillbillybjopkr
Send a private message to Hillbillybjopkr
keep the pictures coming lol....been wanting to do this to my D4-7U for awhile
Tue, Apr 4, 2017 12:14 AM
Norm R2,22
Reply to Hillbillybjopkr:
The mounting bracket is done except for paint. It is 3/16" plate so I doubt it will bend. I will change the connections on the alternator from 12 o'clock to 6 o'clock to put them in out of harms way. This is an old unit that I think works😕. If it doesn't I can get a rebuild kit for about $15 + shipping. So far the total is $8.00 for a bearing and $10.00 for paint. The second bearing, pulley, shafting etc. came out of the scra.... resource pile.
[attachment=41291]Alt drive 9.jpg[/attachment]
Mon, Apr 10, 2017 6:31 AM
kracked1
[attachment=41300]IMG_0119.JPG[/attachment]
[attachment=41301]IMG_0118.JPG[/attachment]
This is what I built for a #12.
Mon, Apr 10, 2017 8:55 AM
