Cam ring for a #41 hydraulic pump
Showing 1 to 6 of 6 results
Mike Meyer
I may be on the lookout for a new or good used cam ring for a #41 hydraulic pump, I found a new rotor here in Oz but my old cam ring is pretty nasty with old water damage and general wear, can someone please suggest a good place to find one, my old cam ring has 114172 engraved on one face so I'll assume that is the part number, the #41 pump itself has no serial number tag unfortunately.
Mike
Sat, Feb 25, 2017 4:30 PM
Hi Mike, my tag was missing and I swore there was no stamping but there was, under the rust.
Sat, Feb 25, 2017 8:26 PM
Thank you received: 16
Plug Vickers 114172 into a google search and several sources come up.
Sat, Feb 25, 2017 11:15 PM
Mike Meyer
Hi Neil, I scrubbed that area when I had the pump on the bench and unfortunately couldn't see any numbers.
Sun, Feb 26, 2017 3:27 AM
Mike Meyer
Hi Pete, thanks for chiming in, my Google search turned up one on Fleabay Canada and possibly a re-manufactured one at a aircraft supply firm, do you know the actual Vickers pump number for that #41 pump?
Mike
Sun, Feb 26, 2017 3:33 AM
Reply to Mike Meyer:
Mike
My internet access to interchange is no longer supported but I believe it is a Vickers model V200 11 pump as shown here. (114172 ring & 912067 cartridge kit).
http://www.eaton.com/ecm/groups/public/@pub/@eaton/@hyd/documents/content/pll_2376.pdf
Ring available here....
http://www.ebay.com/itm/NEW-VICKERS-114172-RING-/172292520533?hash=item281d6f3a55:g:1GkAAOSwdzVXoMKP
And another shelf worn, light rust new one here...
http://www.ebay.com/itm/Vickers-Ring-114172-/282011775149?hash=item41a93630ad:g:2jgAAOSwiYFXF7Fq
There's also another new one out there for $459 but I figured you wouldn't want that one.
Sun, Feb 26, 2017 4:45 AM
Mike Meyer
Thanks Pete
Regards
Mike
Sun, Feb 26, 2017 5:00 AM
| 34 Henty Hwy, Warracknabeal
Veerkamp Open House 2025
| Placerville, CA
Stradsett Park Vintage Rally
