Does the 17A have factory hydraulic adjusters or the aftermarket conversion type shown in GP's video. The adjuster portions are not the same.
Daron, when I repaired Pops 14A hyd adjuster (other repairs too) we split the tracks. If Petes bringing his mega sledge to drive the track pin out make a holder that will bolt to the track pad and hold the punch for you. If you torch the pins make an X in the pin ends then your large punch won't get wedged inside the pin.
