Converting a Caterpillar 8T 12 grader from 6v to 12v
Showing 1 to 9 of 9 results
D2 Cody
Send a private message to D2 Cody
Hi guys,
We are thinking of converting our old 12 over to 12 v and was wondering what you have found to be the easiest route of going about this. Any info would be greatly appreciated. Thanks in advance.
Cat D6C 76A2045
Cat No. 12 8T15616
Caterpillar-Dodge-Lincoln-Stihl-Echo-Craftsman
Mon, Jan 23, 2017 1:14 PM
Probably one of the alternator adapter mounts would be the best way in my opinion. That way you have good capacity in a unit that can be easily replaced with a standard readily available and cheap component.
There are the off the shelf adapters that mount the alternator direct drive through a lovejoy type coupling and then I have seen pictures of some that were belt driven off a pulley mounted on the rear end of a shortened, gutted generator. Very common to use a 10 or 12SI Delco. These were used on GM vehicles for many years so they are common and relatively cheap.
Tue, Jan 24, 2017 3:28 AM
D2 Cody
Thank you for the reply ccjersey. Do you by chance know if any place that sells these adapter kits. Thanks again Cody.
Cat D6C 76A2045
Cat No. 12 8T15616
Tue, Jan 24, 2017 8:33 AM
mrsmackpaul
Reply to D2 Cody:
only a month or two ago there was talk about this type of conversion but not on a grader, cant remember what it was but here is a link to a mob in Texas I think
http://www.auto-lec.com/directstart.htm
Paul
Tue, Jan 24, 2017 9:27 AM
Paso Bob
Reply to mrsmackpaul:
Paul
Florin Tractor in Sacramento has ready made single wire alternators for various Cat applications. Their telephone number is (916) 383-0317.
Tue, Jan 24, 2017 12:53 PM
Thank you received: 7
Reply to Paso Bob:
There's also a shop that makes 6v alternators that "look" like generators, with the long body shape. They look pretty cool and still put out the amps and don't need an external regulator (although for that authentic look you could still have the original regulator there, but just with the terminals re-wired). Only problem is they're priced for the premium market... I'm very keen to keep my D2 6v despite the advantages of going to 12v, just because I want it to be original, so the pony starter might need some attention so that the spin speed is adequate
Tue, Jan 24, 2017 7:29 PM
oldbeek
I use a solargizer battery maintainer on my CAT 12 and my Kobelco tractor and my RV. Unless you are using headlights, these units keep your battery in top shape. The army national gaurde uses them on all their equip. It also knocks the sulfation off the plates of the battery and makes your battery last longer. Bought one on ebay recently for $30.00 Just checked Amazon. The 2 watt that i use is $68.00. That one works on 6 to 36 volts. They also sell 5 watt Chargers for about $170.00
Wed, Jan 25, 2017 8:06 AM
jumbo
Send a private message to jumbo
Reply to oldbeek:
When I did my 212, I used
http://www.ccbattery.com/Cat--Conversion.html
This style are all about the same price, this looked nicest.
I'm not afraid of hard work; I can lay down beside it anytime and take a nap.
Wed, Jan 25, 2017 8:25 PM
Reply to jumbo:
Which ever alternator conversion you go to I'd suggest you get one with the Delco 1-wire alternator and avoid the ones with the Motorola version.
Wed, Jan 25, 2017 11:06 PM
DPete
I did one several years back, took the gen to a auto electric shop, they converted it to 12V by changing the coils etc. An alternator is superior but it might still be an option if you can find somebody today who has the knowledge of where to get the parts or if they are still available. Still looks stock that way
1962 D4C
Wed, Jan 25, 2017 11:38 PM
Veerkamp Open House 2025
| Placerville, CA
Stradsett Park Vintage Rally
Chapter 2 The Link Club's AGM
