D6 winch compatibility
Showing 1 to 10 of 11 results
Catboy1
Send a private message to Catboy1
Hi, it's been awhile since I posted anything to you guys. Awhile back I mentioned a parts dozer I was looking at and by the engine serial number, it was figured it was a D6B. It has a D6C winch mounted on it and I was wondering if that would fit my 9U? It also has hydraulic track adjusters and segmented sprockets. Has the undercarriage been upgraded? Thanks for all of your time. Robyn
Tue, Jan 10, 2017 10:52 PM
Thank you received: 13
All that D6B stuff will interchange on the 9U.
Tue, Jan 10, 2017 11:02 PM
Catboy1
Thanks for the reply, Old Magnet. It's missing it's electric starter. Do you have a part number for it?
Wed, Jan 11, 2017 12:38 AM
Reply to Catboy1:
Original inertia drive starter is a 5H0455 replaced by a 9H3580. These are the old style Delco 40MT motors.
I'd recommend replacing with the later conversion 40MT or 42MT with the direct mounted engagement solenoid.
edit:
I'm assuming the 9U is missing the starter?
Wed, Jan 11, 2017 3:44 AM
Catboy1
edit:
I've looked around a bit online and I'm having trouble finding that new part number. If I go to delcoremy, there are a lot of options for 42mt. How do I know which configuration it is?
Wed, Jan 11, 2017 4:33 AM
Reply to Catboy1:
That's why it is called a conversion. The only part of a standard 42MT starter used is the clockwise rotation motor. The lever housing (on some/not all) needs changing along with a special drive end housing and a new helical gear drive. You won't find this conversion as a standard commercial option.
Wed, Jan 11, 2017 5:19 AM
Catboy1
It's the D6B that's missing the starter. I figured the easiest way onto a trailer was under power. My 9U is pony start, which I much prefer. I don't think I'm willing to go through all the effort of a conversion just for that. Is the conversion my only option?
Wed, Jan 11, 2017 5:28 AM
Reply to Catboy1:
Not the same for the D6B. If it had the original starter and straight tooth flywheel ring gear you need an original 8H1913 40MT clockwise starter plus the 1M0023 adapter or a later 42MT starter with the same adapter and straight 11 tooth drive.
Current number appears to be a 4N8118 (40MT) or find a 42MT equivalent.
Wed, Jan 11, 2017 6:04 AM
Catboy1
Thank you Old Magnet.
Wed, Jan 11, 2017 9:21 AM
old-iron-habit
Reply to Catboy1:
Anything there to pull start it with?
Wed, Jan 11, 2017 10:02 AM
Catboy1
Reply to old-iron-habit:
There are a few machines there but I'm afraid they're all in similar condition.They have a D8 they are trying to sell as well, and a tracked gradeall. It's also in a very unaccessable spot, backed against some trees and facing more trees.
Wed, Jan 11, 2017 12:14 PM
CAFES 2025 TULARE, CALIFORNIA
| Tulare, California
| 34 Henty Hwy, Warracknabeal
Veerkamp Open House 2025
| Placerville, CA
