D7 48A thoughts / opinions
Showing 1 to 6 of 6 results
mog5858
well i had to stop and look at a cat that i saw in my travels. it a 48A 4898 was not really think about adding any more cat's but the end deal i might have a "JOB" for it to pay for it self and i be left with a cat:dance:. as i still just a young pup what you do guys think about this cat. i never thought i would make the jump to power-shift as it scares me a little if anything when wrong with it cost wise. but i know that the d7E have a fairly good reputation. the job i would be about 100 hours before she would be left for a play toy. she is a pony motor start. but not really sure what else to check out on the bigger cat's the idler looks a little worse for wear but i am not a expert the pins have bean turned. if i get everyones .02 cents i might have enough for a down payment. lol
Sun, Jan 8, 2017 11:42 PM
sprockets look decent and they are segmental---measure the rail height at its thinness spot--looked a little worn--idler is worn but may get the 100 hours out of it.---on the power shift pull the filter and cut it open and look for metal particles---if you do buy use the Cat spec TO4 transmission oil
Sun, Jan 8, 2017 11:54 PM
JDcat
Send a private message to JDcat
Reply to dpendzic:
Track looks quite loose, check to see if there is any adjustment left to tighten them.
John
Mon, Jan 9, 2017 3:50 AM
Wombat
Donor
Reply to JDcat:
John
I note the current owner must love it as it is wrapped up in cotton wool.:dance::dance:
I cant see any reason why the tracks wouldn't do 500 or 600 hours and maybe many more, my view tracks aren't worn out until they stop driving, then weld some knobs on the sprockets to go again.
The Mad mouth From The South
Mon, Jan 9, 2017 7:42 AM
seiscat
Reply to JDcat:
John
Hi mog5858, if the job you have lined up will come close to paying for the D7E it's worth a try. Don't be afraid of the powershift transmission, they are actually easier to rebuild than a direct drive. The first photo shows that the tracks are/were S.A.L.T.(Sealed And Lubricated Tracks) which means the tracks have a master link so the tracks can be removed by un-bolting the master link instead of having to press out a master pin. The tracks might have had a "dry" turn but they are still a plus. Overall the tractor looks good from the pics.
Beware: Once you get used to operating a powershift 'dozer you will be spoiled and will no longer be satisfied with a direct drive. I repeat, don't be afraid of the powershift transmission if you are capable of doing your own repairs. The trans and torque converter are not difficult to rebuild, just get a service manual and you will be amazed at how easy it is. :cool2:
Craig
Mon, Jan 9, 2017 7:57 AM
catdozer876
Send a private message to catdozer876
Reply to seiscat:
Craig
I am working on getting a D7E back and running after sitting for 29 years. They are very well built machines! Did you speak with the owner? Ask him about the history of the dozer, this may help you make a decision. I would meet him in the morning and do a cold start. Run it for awhile and see how everything works when it warms up. You can do a lot of work with a D7 in 100 hours. Plus and more importantly, you might very find it enjoyable to own and operate! Best of Luck!
Mon, Jan 9, 2017 8:12 AM
mog5858
Reply to catdozer876:
thanks guys for the feed back. i guess i will have to look in to this a little further and see where it takes me. nice to hear about the SALT rails did not pick up on them at the time of looking.
Mon, Jan 9, 2017 10:10 AM
CAFES 2025 TULARE, CALIFORNIA
| Tulare, California
| 34 Henty Hwy, Warracknabeal
Veerkamp Open House 2025
| Placerville, CA
