3116 truck engine trouble
Showing 1 to 10 of 47 results
jaker65
Send a private message to jaker65
Hey all,
We have a truck with a cat 3116 engine in it. The truck runs good but after it sits overnight, it is hard starting it. Seems like it is losing its prime. I was wondering where I should start with this. Any help is appreciated. Also if anyone can provide me with the correct engine oil to use in this engine would help me too. I know most use 15w40 but I guess I'm just old fashioned and want to use original in it. Thank you for any and all help.
Thu, Dec 29, 2016 7:37 AM
ms0115
Send a private message to ms0115
What kind of truck is it in?(Top Kick) Do you have an intake heater light on when starting? Does it do it all the time or just when it is cold?
Thu, Dec 29, 2016 8:04 AM
jaker65
Reply to ms0115:
Yup it's a top kick. No it does not have a intake heater. Just a standard engine. Does the injection pump have a screen on the intake side on the pump itself? I seen one that has had it on it before. Just a little unsure. And yes it does do this all the time if the truck sits overnight. During the day after initial start up, it will start up no problem. Just when it sits overnight, the next day it takes some cranking to start it
Thu, Dec 29, 2016 8:54 AM
crbearden
Send a private message to crbearden
Reply to jaker65:
I had a 7.3L Ford Navistar that did this. If you have the HEUI injection system then they are basically the same. The high pressure oil pump can leak down and then must pump back up to hydraulic pressure to actuate the injectors before it will start. On the Navistar it took a rebuilt HP oil pump.
Thu, Dec 29, 2016 9:02 AM
mrsmackpaul
Reply to crbearden:
First thing to do is see if its loosing prime and this is easy look at the exhaust when you wind it over if it has little or no smoke you know you are loosing prime
If you are loosing prime its in the return to the tank side of the fuel system also check the pipe the runs down to the bottom of tank on the return is still attached
If you are loosing prime when you are driving its on the supply side if its when its not running its on the return side
It really is this simple if you cant find any leaks put a pair of vise grips on the last hose that returns to the tank and run it as on any motors I have worked on this builds pressure and you can soon find plenty of wet spots
Paul
Thu, Dec 29, 2016 10:12 AM
catsilver
Reply to mrsmackpaul:
Paul
3116 was 'mechanical' fuel injection, there is a screen in the inlet line just above the pump drive behind the timing case try using the priming pump before trying to start to see if it makes a difference. Fuel pressure is limited by the strength of the lift pump spring, also fuel run back can be caused by worn check valves in the lift pump. Make sure you only use the correct 'Cat' high efficiency fuel filters as any dirt getting through will soon wreck the injector pumps.
Thu, Dec 29, 2016 3:09 PM
jaker65
Reply to catsilver:
This is gonna sound dumb but I was crawling all over the engine to find the priming pump and can't for the life of me find it. Couldn't be easy like the 3208 lol I just hope it's something easy. I'm going to go get a Napa fuel filter today for it and check that screen out on the pump. Hope it's just something stupid like that.
Thu, Dec 29, 2016 3:39 PM
DPete
Reply to jaker65:
Read Catsilvers last sentence, I got chewed by a Cat mechanic for using aftermarket fuel filters years ago. Who knows what micron they are? His words were " Cat designs their fuel filters to protect their systems" I never used aftermarket again
1962 D4C
Thu, Dec 29, 2016 11:19 PM
jaker65
Reply to DPete:
I believe what you say about cat filters. I just can't afford them nor the 60 plus Mile drive to the dealership to get them. Napa has always worked for me and the equipment I own. 2nd best isn't always bad plus I trust them more since my friend use to drive triaxle for a living. He used Napa filters all the time. His cat engine in that truck lasted 800,000 miles before it needed repaired. But anyhow, I'm still at a loss trying to find the manual fuel pump on this engine if it has one at all.
Fri, Dec 30, 2016 12:55 AM
d9gdon
Reply to jaker65:
Cat is famous for being very expensive on equipment and replacement parts. Their filters are not expensive. Most of the time in my experience, they are cheaper than aftermarket.
Fri, Dec 30, 2016 2:55 AM
jaker65
Reply to d9gdon:
Ok gonna go back to topic here, I went out and tried to start it today. Same thing hard starting lots of cranking and blue smoke this time even after the engine was warmed up. Still ha v e the same questions about the priming pump, but my next question is, where would the check valve be on the pump? I'm gonna guess it's right on the return line coming straight out of the pump. Hope this picture is some what correct
[attachment=39537]1325i15B2E920EFD3B52F.jpg[/attachment]
Fri, Dec 30, 2016 3:18 AM
| Hartley - South Australia
