Off Topic Brake re-lining
ETD66SS
Send a private message to ETD66SS
So, I am working on a toy that I bought this past summer, a Pettibone Extendo 88 High Lift:
[img]http://i.imgur.com/46YJm3M.jpg[/img]
I am working on it this winter to get it ready for use next spring/summer. I am currently working on the parking brake. The machine has hydraulic brakes at the wheels, which don't work atm, as well as a hand lever operated parking brake at the rear of the transmission:
[img]http://i.imgur.com/wXghNIo.jpg[/img]
The brake band was seriously wiped out, so I priced a new one. ~$187.00 for a new band. I thought that was absurd, so I put the band on my outdoor grille and heated the crap out of it, got the old brake lining material off. I was able to buy some new lining material: https://www.mcmaster.com/#6224k346/=15gyuhs
At the moment I am shaping the new lining by clamping it between the band and the drum:
[img]http://i.imgur.com/V17WNqo.jpg[/img]
When googling about how to re-line bands/shoes, Pliobond adhesive kept popping up, and seemed like the best solution for the adhesive. I bought some Pliobond 25 & 35:
[img]http://i.imgur.com/dPzbI2h.jpg[/img]
Has anyone here ever re-lined old shoes? I'm going with adhesive because that's how the original was assembled, and this is only a parking brake, so not applied when driving.
I've read all the documentation on the Pliobond, and I must say it's a bit confusing. There are wet bonds, dry bonds, hot bonds, cold bonds, different materials use different adhesives, not sure I can mix them (put the 25 on the steel band, and the 35 on the fibrous lining material etc).
Before I start gluing, I'm hoping maybe someone here has experience doing this kind of brake restoration and has tips/pointers on the bonding process.
Thu, Dec 15, 2016 7:46 AM
Andrew
I would drill it and rivet it.
Glue it also if you desire.
Thu, Dec 15, 2016 12:29 PM
ETD66SS
Reply to Andrew:
[quote="Andrew"]I would drill it and rivet it.
Glue it also if you desire.[/quote]
Well, The original lining was 3/16" from what I could tell, if I was going to rivet I probably should have bought the 1/4" thick lining material. I don't think I have enough thickness for rivets now. Also, I'm wondering how I would do the counterbored holes on the inside of the lining. This lining material is very stiff, and it's not like I can mark out the holes then get it flat to do the drilling.
I guess I will try the "hot bonding" method and see how it goes. It's supposed to be the strongest bond type. Was just hoping someone here has used Pliobond before is all...
Thu, Dec 15, 2016 5:56 PM
mrsmackpaul
Reply to ETD66SS:
I would glue it thats all any of the brake places do these days and I have never heard of one coming off
Paul
Thu, Dec 15, 2016 6:01 PM
Steve A
Reply to mrsmackpaul:
Paul
I just dropped of a clutch for bonding, its a flat clutch but I was told it would be done in a oven at 350F with 10 tons of pressure on it, the guy told me they typically do a stack of them at a time. As it turned out the shop owner is a old tractor guy and was willing to do my small job for a 12 pack of Cores out the back door.
Thu, Dec 15, 2016 6:19 PM
ETD66SS
Reply to Steve A:
Yeah, I think what I am going to do is put the Pliobond 25 on the brake band, the 35 on the lining, let both dry, then clamp the band & lining to the drum and place it in the oven at 350 deg for 1 hour.
We'll see how that works out.
Thu, Dec 15, 2016 6:23 PM
