Caterpillar 12 8T circle reverse
Showing 1 to 10 of 28 results
D2 Cody
Send a private message to D2 Cody
Hi guys,
I was repairing a waterway for a local farmer with my blade and when I got to the end I could not get my circle to spin left. I can pull the lever and it will spin right but when I push it forward to spin left the shafts don't move and the lever goes forward but will not move the circle. Is there a shear pin or something I need to find and repair? :confused2:
Cat D6C 76A2045
Cat No. 12 8T15616
Cat D2 5U 15751
Sun, Dec 11, 2016 1:38 AM
Thank you received: 65
Hi, D2 Cody.
From what you have posted, it seems to that the problem is inside the control box, probably with either the dog clutch or the drive gear but possibly the control fork for the front dog clutch. If memory serves me rightly, early models of Cat 12s had both dog clutches on one gear controlled by one fork while late models had separate dog clutches for the front and rear gear trains with separate forks for each dog clutch. I don't know when the changeover was.
BTW, that circle reverse control drive shaft also carries the gears that distribute the incoming power from the vertical power shaft to the rest of the gear train in the control box. If you have to get it out, you will need to remove the universal yoke in front of the cab and also take out the half-moon key after you have removed the yoke.
I would suggest starting by draining the oil from the control box and removing the front cover so that you can inspect the 'innards' to see what is the problem. The dog clutch control fork would be the easiest fix. There is nothing really frightening in there. You just need to look carefully at it and 'figger' it out. The correct parts manual can help heaps. If you have that, you will be ahead of where I was any time I ever had to go into a control box.
Sun, Dec 11, 2016 4:18 AM
Thank you received: 22
Hi, D2 Cody.
Takes a s/n to get the right answers.
Sun, Dec 11, 2016 7:20 AM
D2 Cody
Serial is 8T15616
Cat D6C 76A2045
Cat No. 12 8T15616
Cat D2 5U 15751
Sun, Dec 11, 2016 7:48 AM
Reply to D2 Cody:
Serial is 8T15616
There aren't any shear pins in the control tower other the on the tower main drive shaft. Seems you have a control problem. Controls for that s/n came in the original version or field installed option.
Sun, Dec 11, 2016 11:15 AM
Hi, Old Magnet.
To the rescue - AGAIN. Thank you, Sir.
Hi, D2 Cody.
In O.M.'s first image, you can see that the gear at the front of the control box - nearest the levers - only has one set of teeth while the gear shown at the back of the box has 2 sets of teeth, a straight set and a bevelled set. Because of the detail of the cutaway, these 2 gears are shown on different shafts in the diagram.
Under that bevelled gear, you can see another bevelled gear laying horizontal in the bottom of the control box. That gear is on the top end of the vertical power shaft coming into the control box. The shear pin that Old Magnet mentioned is at the bottom of that shaft inside a swinging door flap between the operator's feet. That is not your current problem by the what you describe.
If you still have all other functions on the 'push away' side of the control box, the best bet I can think of is a problem with the dog clutch or the engaging mechanism on that control shaft. I can't see that your are going to be able to fix it without going into the control box itself. As I said earlier, don't be frightened of it. Take your time and observe it all to see what makes it tick and you will likely have no problems.
Sun, Dec 11, 2016 12:33 PM
D2 Cody
Hi, Old Magnet.
Hi, D2 Cody.
[attachment=40267]0217171113a.jpg[/attachment]
Hopefully pic shows up this is my first time. This is the shear pin at bottom of shaft running up into box. My question is does it look like the bottom piece where the bolt comes into from the top is broke in two
Cat D6C 76A2045
Cat No. 12 8T15616
Cat D2 5U 15751
Sat, Feb 18, 2017 12:18 AM
D2 Cody
Reply to D2 Cody:
Pic showed up but is up side down
Cat D6C 76A2045
Cat No. 12 8T15616
Cat D2 5U 15751
Sat, Feb 18, 2017 12:19 AM
Reply to D2 Cody:
Yes, picture is upside down and it looks like the ear that receives the shear pin is broken/split.
Going to need to replace or repair coupling assy. 8B3010
Sat, Feb 18, 2017 12:31 AM
D2 Cody
Hi old magnet,
Boy I'm sure glad you are a member of this forum Thank you so much for all the help over the years. Do you know what a guy does about this problem. Also could that be the reason the blade will circle right then go a little bit left then just make the lever chatter and not do anything? Also it looks like a bearing is out because there is a bearing that is sliding up and down on the shaft above the shear pin.
Cat D6C 76A2045
Cat No. 12 8T15616
Cat D2 5U 15751
Sat, Feb 18, 2017 12:37 AM
Reply to D2 Cody:
Hi old magnet,
See edit above. No bearing to drop down. I suspect you are seeing seal #5B6129 that has got loose. Without positive shear pin connection you have no accurate control of functions.
Sat, Feb 18, 2017 12:46 AM
