D2-5U dimensions - no blade, no engine
Showing 1 to 10 of 13 results
Thank you received: 19
Hi all, I need to pick up a 5U rear end with undercarriage/tracks but no engine/radiator/fuel tank.
Please confirm the overall width is 5' 6" same as the 5J, overall length 8' 11" (although this has no engine so it'll be shorter than that - a bit longer than the track length).
What would the weight be with no blade or equipment, no engine/radiator, no fuel tank - basically the transmission back, and the undercarriage/tracks? I'm guessing around 4000#?
I'd tried to find this information with search - I got the specs for the 5J but couldn't find the corresponding 5U info so apologies if it's already there.
Thu, Oct 27, 2016 8:22 PM
STEPHEN
If the pads are the same width, it would be so close to the 5J you would have to squint to see it.
Thu, Oct 27, 2016 11:48 PM
Reply to STEPHEN:
Neil--my 5U parts book has width 5-'5 3/4"---length--8' 11 7/8 "----weight--7430 #----i think your very close with 4000# weight
Fri, Oct 28, 2016 1:04 AM
Reply to dpendzic:
D2 U Model specs...
Fri, Oct 28, 2016 2:32 AM
D2 U Model specs...
Pete---the weights don't match---what could be the difference??
Neil--i have a 10000 gvw tilt trailer in Ma that you could use--it is 69 inches wide on the deck between rails--electric brakes and all lights work--standard 7 prong connector
Fri, Oct 28, 2016 4:20 AM
Reply to dpendzic:
5U1-13236 is 6,870 lbs
5U13237-up is 7,430 lbs (longer case)
Fri, Oct 28, 2016 5:05 AM
You could put that on a U-Haul trailer provided the track pads fit between the fenders.
Fri, Oct 28, 2016 6:23 AM
Reply to drujinin:
Heh, I looked at uhaul - they have a 6x12 internal dimensions that's only good for 2600#, and a "car trailer" that's good for 5900#, but they want to see the car on it. Amazingly, they did not have an option online to select a 1950 model year Caterpillar D2! Still can't believe it ; )
I'm hoping that it will work out to borrow a member's gooseneck but if I wanted to wing it with the uhaul, I wanted to check that it would fit.
Dan, thanks very much for the offer! I'll probably go local because I'm not a fan of long distance (more than 30 minutes : ) driving but much appreciated in any case.
I should remember to go over the scales and see just what it weighs.
Fri, Oct 28, 2016 7:11 AM
janmeermans
Neil,
We have a truck rental outfit out here - Penske. Don't know if they are back there or not. There used to be Ryder back there. Anyways, I can get a F-550 with a 16' flatbed and hydraulic liftgate for $95/day and $0.29 per mile. You would have to figure out the loading/unloading and a loading ramp/forklift on each end. Also, the Big Tex dealer here in S CA will rent a large equipment trailer if you give them enough time to schedule it.
Jan
Fri, Oct 28, 2016 10:57 AM
chuckb
Reply to janmeermans:
Neil,
Jan
a good "bobcat" trailer will work should be wide enough and definitely strong enough
Fri, Oct 28, 2016 8:42 PM
Reply to chuckb:
Hi Jan,
I checked out Penske too and see that they have a bunch of stuff to hire. Tim, one of our local members, is graciously lending me his trailer so I'm all set - 14k gooseneck so there's plenty of capacity.
Fri, Oct 28, 2016 8:55 PM
Newby Hall Tractor Fest
