torque spec on flywheel bolts
oldbeek
Cat 12 8t with d315 6 cyl motor. Cap screws are 3/4 fine thread. What is the torque?
Wed, Oct 26, 2016 8:11 AM
Standard grade 8 bolt torque, 260+-30 ft lbs. Tighten to 260 then turn to properly bend lock to bolt head.
Wed, Oct 26, 2016 8:42 AM
oldbeek
i found a chart on google that had 315 lb for a 3/4 in grade 8 Thanks for the reply. Done and torqued. Clutch back in and ready to reinstall engine. Yea !! going back together!
Thu, Oct 27, 2016 10:14 AM
Reply to oldbeek:
The specs I gave are from the Cat Service Manual for standard bolt torque specs. Bolt torque for the 3306 engine flywheel is 150+-20 ft lbs which is the torque for 5/8" bolts. The torque for 3/4" bolts is 265+- 35 ft lbs.
Fri, Oct 28, 2016 4:28 AM
mog5858
a 12-8T with 315? should it not be the bigger 318? as the 315 would have bean in the 112? my 12-7T run's a 4600
Sat, Oct 29, 2016 9:01 PM
oldbeek
Reply to mog5858:
Your right. I have a problem with numbers in my head getting down on paper correctly. Thanks
Sun, Oct 30, 2016 10:38 AM
| Hartley - South Australia
