941 input shaft seal replacement
Showing 1 to 10 of 11 results
wlf89
Send a private message to wlf89
what will i have to do to replace the input shaft seal on the torque converter? it has been seeping since i have owned it,i figure from it sitting up and drying out before i bought it,but now it is leaking pretty good.
will the engine or trans have to be removed? i dont figure im lucky enough that it can be changed by removing the flexible coupling and get to it that way?
Sun, Sep 11, 2016 4:28 AM
Thank you received: 39
Removing the flex coupling will give you access to change the front torque converter seal.
Sun, Sep 11, 2016 6:07 AM
Glum
Can be replaced by removing the flexible coupling. Bit tight for working room. Be careful installing the new seal.
Sun, Sep 11, 2016 11:50 AM
wlf89
Reply to Glum:
does anyone know the part # for the seal? not seeing it in my parts book.
Sun, Sep 11, 2016 7:05 PM
Reply to wlf89:
1D4326 in my 80H1-3039 parts book.
Sun, Sep 11, 2016 11:32 PM
wlf89
i got the seal out and the next question i have is the shaft has a decent amount of play in it up and down id say maybe 1/8". should i drop the trans and change the bearings or put a seal in it and hope it last me a while? i only use this dozer on the farm in free time its not like its a money maker for me.
Tue, Sep 13, 2016 12:05 AM
Reply to wlf89:
A new seal with 1/8" + movement isn't going to last very long.
Tue, Sep 13, 2016 12:47 AM
catsilver
If the shaft is going up an down that far, the oil seal wont last long nor will the converter seals, time for a re-bearing/ reseal job before a major failure. the transmission complete or converter on its own is best taken out underneath.
Tue, Sep 13, 2016 1:00 AM
wlf89
Reply to catsilver:
thanks guys thats what i already knew was just hoping to hear yall say it might last a while lol
any tips on taking the trans/converter combo out? im thinking a chain wrapped around the rops roof and a chainhorse to lower it on the belly pan and then drag the pan out.
manual says there is 1 bolts in the rear and the support bracket bracket, doesnt mention nothing in the front and i dont remember seeing nothing while under there, is there nothing holding the front end up?
Tue, Sep 13, 2016 3:46 AM
catsilver
Reply to wlf89:
You need to block the machine up high enough to get the transmission back underneath, apart from all the linkages etc, there is a ring of bolts holding the transmission to the back end casing, it comes out complete with transfer case and pinion. the whole flywheel coupling has to come out. I can't remember what supports there are each side of the transmission, the last one I removed was in 1975 over a ditch at the edge of a field using a 'Hiab' crane through a hedge and through the cab door, so a pull lift around the ROPS should work quite well.
Tue, Sep 13, 2016 5:19 AM
Glum
Reply to catsilver:
The converter should be able to be dropped without removing the transmission. It can on the D4 so I imagine the 941 won't be too different.
Tue, Sep 13, 2016 10:30 AM
