undercarriage interchange parts swap
Showing 1 to 10 of 14 results
bcguide
Send a private message to bcguide
is there a list of what track chains and roller can be usesd on diferent machines.
when I had a d68u I used some rollers from an excavator.
Scott
Wed, Aug 17, 2016 1:26 PM
The D5, D6, D6B, 955 12A5793-up plus 955 models H & K, 977 20A1 to 5792 all use the same bottom rollers.
The D6, 955C, E, 12A5793-7685, 977D, 20A1-2508 all use the same top grease type rollers.
The D5, D6, 955E, 12A7686-up, H, K, 951, 951B all use the same lifetime type top rollers but modifications may be required to match the stands.
At one time you could get lifetime top rollers modified to fit grease type stands for the D6, 955, 12A5793-7685, 977D, 20A1-2508 but I do not know of a current source.
Wed, Aug 17, 2016 9:19 PM
bcguide
l got some d6b rollers and stands for a local wrecker so my next question.
My dozer track chain was made by simmel and I am trying to find out what the pitch is so I can keep a look out for spare parts
Wed, Aug 24, 2016 7:19 AM
catsilver
Reply to bcguide:
D6B should be 6.75" pitch unless updated to D5 6.91" pitch.
Wed, Aug 24, 2016 6:59 PM
Reply to catsilver:
Answer the question on your previous post!!!
Wed, Aug 24, 2016 9:50 PM
catsilver
What are you talking about OM, D6 with 6 cylinder engine up to D6B are all 6.75" pitch, unless updated to D5 size 6.91" pitch, There are two sizes of 6.75" pitch track, D4 and D6, so check what machine they have come from.
Wed, Aug 24, 2016 10:49 PM
Reply to catsilver:
Hi catsilver,
I was referencing the original poster who asked the same question previously.
I asked for a tooth count on the sprocket.
The 6.75 pitch is 28 tooth, the 6.91 is 27 tooth.
Wed, Aug 24, 2016 10:58 PM
catsilver
Hi catsilver,
I wondered where you were coming from OM, its always best to get a part number from the links, Cat or otherwise, then they can be identified easily.
Wed, Aug 24, 2016 11:32 PM
bcguide
Reply to catsilver:
k I have 28 teeth on the sprocket
the next time I am near the 955 I am looking at I will see what it has
the cans on both machines are simmel they were bought out by berko and info on the out simmel chains seems hard to find
Was talking to the fellow I got the rollers from for the d6 8u and he tough that they came of a drott excavator
Thu, Aug 25, 2016 12:41 PM
catsilver
Reply to bcguide:
Simmel used to make undercarriage components for many machines as do Berco, the part number on the links may tell us something.
Thu, Aug 25, 2016 2:29 PM
bcguide
Reply to catsilver:
i have more questins and though it would be better added to this thread
would the front idlers from a 955 L fit a d69u?
Thu, Feb 23, 2017 3:42 AM
