Cutting edges?
Cutting edges?
Casey Root
I'm looking for a price on cutting edges for a D6C, 6S blade. Center section is 39 15/16" with 7 bolts, outer are 25 3/4" with 4 bolts and corner bits are 6 bolts each. Total of 27 bolts and nuts required. I'm in central CA and will pick up anywhere between Bakersfield and Modesto and over to Paso Robles. Got a price locally for all 5 pieces and bolts delivered to Coarsegold in the $600.00 range. Seemed high but what do I know. It might be the deal of the century. LOL
Casey
Sat, Aug 6, 2016 5:33 AM
DPete
Cutting Edge Supply 800-3661101 they are in Sac but have a delivery route thru the valley- J&B Tractor parts in Stockton 209-9319100
1962 D4C
Sat, Aug 6, 2016 5:54 AM
Casey Root
Reply to DPete:
Thanks DPete.
Saved $150.00 so far and only spoke to one of them. Have a call into the other.
Sat, Aug 6, 2016 6:22 AM
Casey Root
Reply to Casey Root:
Thanks DPete.
Thanks all for the references. I bought them from Cutting Edge Supply and they were delivered to Fresno today at no extra charge. The other two companies wouldn't return my calls and there was multiple attempts.
Thanks again. It saved $150.00 over a local supplier.
Fri, Aug 12, 2016 7:49 AM
Veerkamp Open House 2025
| Placerville, CA
Stradsett Park Vintage Rally
Chapter 2 The Link Club's AGM
