Caterpillar transformers
Showing 1 to 10 of 24 results
seyser
Saw this post on the Mack site that I frequent. Neat article.
http://www.bigmacktrucks.com/topic/45316-caterpillar-transformers/#comment-334348
Tue, May 24, 2016 9:05 PM
wimmera farmer
Very neat thanks for posting. Will have to search for the full version of "man of wheat".
Did a couple of days planting wheat in 2003 with a Cat in Idaho on those sort of hills scary stuff.
Wed, May 25, 2016 5:31 AM
mrsmackpaul
Reply to wimmera farmer:
[quote="wimmera farmer"]Very neat thanks for posting. Will have to search for the full version of "man of wheat".
Did a couple of days planting wheat in 2003 with a Cat in Idaho on those sort of hills scary stuff.[/quote]
when you find "Man of Wheat" let me know I'll order a copy as well
Paul
Wed, May 25, 2016 6:07 AM
seyser
Reply to mrsmackpaul:
Paul
I would also like to see the full video!
Jeremy
Wed, May 25, 2016 7:58 AM
bruce oz
Thank you received: 16
Reply to seyser:
Jeremy
http://www.pyramidmedia.com/documentaries/man-of-wheat-detail.html
Wed, May 25, 2016 8:39 AM
mrsmackpaul
now we just need the last 23 minutes and we will have it all
Paul
Wed, May 25, 2016 9:48 AM
mrsmackpaul
Paul
just ordered my other 23 minutes I guess they will be here in a few weeks
Who says you cant buy extra time
Paul
Wed, May 25, 2016 9:59 AM
Bruce P
Paul
Cool stuff,thanks for sharing.
you notice that big Versitile tractor in the background in "Man of Wheat" it was tractors like those that spelled the end of the farm Cats
Whitman county is the next county north from us, it's really neat country up there.
Bruce P
Wed, May 25, 2016 7:53 PM
cojhl2
Reply to Bruce P:
Bruce P
Just a few notes to keep history correct:
I am surprised Caterpillar call these tractors bulldozers. We always referred to them as "cats" even if they were red or orange. This type of tractor was built for farming first in CA and someone thought of putting a blade on it way later.
We used cats in this area way before 1946. The cat 60 was a favorite in this area. Horses and mules were delegated to history no later than the beginning of WWII. When I was coming of age the 3cyl was very much in use.
The combines were manufactured with leveling devices from the factory. I don't know about IH but JD finally quit the manufacture of the "hillbillys" sometime in the 80's because it was not cost effective to only build about 200 or less every year. About the same time the radial flow separators came out which made the importance of 100% level less important(The reason for leveling in the first place was to keep the separator level so the shoe could function correctly). Now the big swing frames are gone and the leveling is done with dual wheels and tilting the combine above an axle arrangement.
It is true we always said our cows had short legs on one side so they were level while pasturing. Now it is hard to find cattle grazing on wheatland.
RA Hanson was known for the automatic leveler control. It was the first time the function of running the leveling device could be left up to what today we would call a "robot" I suppose. But the leveling device was still part of the orginal machine.
The self propelled machine presented a challenge to our local farmers and there were a number of them designed, Dave Neal in Garfield as an example.
In fact Dave built a system for a IH-51 that could be controlled from the cat eliminating the combine man. This is just opposite from what as was described in another thread where control of the cat was done from the combine.
Many times I pulled that 36 when the cat tracks were ticking the grain and the header would only be taking about 4ft. I have no idea how it could have been done with 33head of horses or mules up front.
Although the Palouse county has steep land nothing in this area is steeper or softer than the skyrockets around Prescott WA.
Well anyway that's my story and I'm sticking to it!
Wed, May 25, 2016 9:26 PM
mrsmackpaul
Reply to cojhl2:
When you are seeding or sowing as we call it on thus steep country what stops the grain all going to one side of the seed box ?
I guess it might be baffles all the way across
Paul
Thu, May 26, 2016 3:00 AM
Bruce P
Paul
[quote="mrsmackpaul"]When you are seeding or sowing as we call it on thus steep country what stops the grain all going to one side of the seed box ?
Paul[/quote]
Well there are baffles in those drills,the ones that were in the video would probably have three, so there would be four sections. But really most of the time you seed back and forth so if the seed were to shift to one side it would shift back when you went the other way. I suppose when the drills get close to being empty you would have the most chance of running out in the upper end.
Clear as mud?😊
BP
Thu, May 26, 2016 3:18 AM
Stradsett Park Vintage Rally
Chapter 2 The Link Club's AGM
