D6B 44A transmission overheating
Showing 1 to 10 of 10 results
I had purchased a well used D6B 44A (Turboed) awhile back. Anyways my buddy got it back in working order, and has had his workers use it to pull a float to smooth ground for planting. He said the transmission oil is getting really hot after a few hours use. No obvious signs of whining bearings or such. Wondering if they used the wrong type of lube/gear oil? Anyone got any good suggestions? We are puzzled; all I know is the worker made no effort in swapping that tractor for one with an air conditioned cab.......
Fri, May 13, 2016 9:16 AM
mrsmackpaul
what else apart from the transmission does the oil do Im guessing steering servos or something if its a ag crawler I think they might use the oil for the implements but dont know
It sounds like something is pumping thru a relief valve if its get real hot
Paul
Fri, May 13, 2016 3:33 PM
catsilver
Reply to mrsmackpaul:
Paul
There is a turbo on a 44A? I would expect it to get quite warm under the constant load conditions of ag use with the extra power going through it. I'm not sure if the steering booster is fed by the transmission oil, this could cause the oil to warm up if he steering clutches need adjusting.
Fri, May 13, 2016 6:14 PM
seiscat
Reply to catsilver:
D6B 44A6857-UP were high hp, 44A1-6856 offered a turbo as a “high-altitude normalization option”. The steering booster has a separate oil reservoir and steering would not cause the transmission to overheat.
The Operation and Maintenance Instructions book lists the transmission oil as 10½ gallons Series 3 30wt. engine oil. The wrong viscosity oil could cause a heating problem but not to the extreme described. I do not like to use Transmission and Drive Train Oil in a Direct Drive transmission, but that that is just my opinion. Series 3 oil is still available in my area and that is what I use.
The cause for the transmission to overheat would most likely be bearing failure, but there would be additional symptoms.
I wonder if the operator is actually checking the transmission oil dipstick or if he could be checking the oil-clutch dipstick. If the clutch needed adjusting and was slipping even slightly, the clutch oil would rapidly overheat.
I suggest you get an Operation and Maintenance Instructions book for this tractor; they are sometimes available on ebay.
Fri, May 13, 2016 8:25 PM
Reply to seiscat:
How hot is hot? TDTO SAE 30 should be good to 104 deg F. ambient. Next choice is TDTO SAE 50. Nothing but excessive bearing wear or wrong lube to cause overheating. Same configuration as the 8/9U's.
Fri, May 13, 2016 9:15 PM
ronm
I believe I see your problem...
Fri, May 13, 2016 10:02 PM
The constant load of pulling an implement is very different from dozer or even scraper work. The transmission and final drives will get hot a lot faster and stay hot all day long pulling implements. We hooked our 9U to a heavy disk to chop some scrub and brush a few years ago and quickly discovered the cooling system was not up to snuff! Had had no problems while using the dozer before that!
There are any number of miracle fluids that claim to reduce friction and heat in drive train applications, but I agree with seiscat, the first thing I would do is to use a light gear lube vs a powershift transmission (TDTO) fluid or even a motor oil. Something spec-ed for over the road truck transmissions like Road Ranger etc should be about the best possible choice for good lubricity and long life.
Fri, May 13, 2016 10:23 PM
Thanks for the replies. I will "borrow" my tractor back, and most likely run lit through my own shop and see if I can spot the issue. Who knows, maybe there isn't even a problem. I've had truck drivers and equipment operators that would freak out over sights and sounds they "think" they heard.... Kind of like being hypochondriacs. JM
Fri, May 13, 2016 10:56 PM
7upuller
Hey JuiceMan,
I think since there wasn't an enclosed dust free cab with AC and a Stereo, that the tractor has lots of problems... Better shut her down... And get a new one with Auto Steer and GPS. And deliver a Mocha for their Break Time Too...hahaha
Fri, May 13, 2016 11:02 PM
catsilver
Reply to 7upuller:
Hey JuiceMan,
Correct. the steering clutch booster has its own reservoir, how hot is hot? If the transmission has the correct oil in it and there is no bearing whine, there is probably nothing wrong with it.
Sat, May 14, 2016 1:55 AM
gemdozer
Thank you received: 8
Reply to catsilver:
Make sure it't the wet master cluch is not over full or your brake is too much adjusted it is happen on d7
Sat, May 14, 2016 3:01 AM
| Hartley - South Australia
Newby Hall Tractor Fest
