Weight of D9 49a 162
Showing 1 to 10 of 43 results
7upuller
Hey Team,
Can someone tell me the weight of a 49a-162 with a hydraulic dozer and a safety canopy on it. Just a draw bar on the back. What year is it?
Glen
Sun, May 1, 2016 6:34 AM
brian18a
built 1959.
Sun, May 1, 2016 6:44 AM
old-iron-habit
Reply to brian18a:
built 1959.
Sounds like it could be a cool pooooosh Cat. Is it pony or direct start?
Sun, May 1, 2016 7:21 AM
Thank you received: 90
Reply to old-iron-habit:
Sounds like a job for your 9 axle! Buy it or else!
Sun, May 1, 2016 8:44 AM
7upuller
Hey Juiceman,
I'll have to check in with D4e, but I think I can Bonus Purple Five it. It will be close. I can only haul one of the 9's at a time though!!! Hahahaha
Sun, May 1, 2016 9:02 AM
Thank you received: 45
Reply to 7upuller:
Hey Juiceman,
Hi, Glen.
Just guessing but I think it would be in about the same ball park as the M47. I did a search for the specs on the 'net but it came up missing.
Sun, May 1, 2016 9:31 AM
Thank you received: 19
Reply to 7upuller:
Hey Juiceman,
Got one sources that says 60,000 lbs, another says 70,000 lbs.
That's for bare tractor. I tend to believe the lower number.
Sun, May 1, 2016 9:32 AM
brian18a
parts book says 61800 bare with fluids. That may not include belly pans, roller guards. Blade should be a bit more than 10000. Canopy depends on how heavy duty it is.
Sun, May 1, 2016 9:50 AM
Bruce P
Reply to brian18a:
66,025 lbs. This was in 1956 so I'm not sure if it's the same as your 1959 model. I have no idea how the test tractor was equipped, but I would assume bare.
Hope this helps
Bruce P
Sun, May 1, 2016 9:55 AM
7upuller
Hey Team,
I'm going with 60,000 bare, around 3000 canopy, and 15,000 blade. So 78,000 to 80,000 lbs. let me know if anybody has specs.
Glen[attachment=35310]image.jpg[/attachment]
Sun, May 1, 2016 10:00 AM
Reply to 7upuller:
Hey Team,
Another source (Caterpillar Performance Handbook) says basic machine weight of 59,837 lbs. Build up on 60,000 lb base sounds right to me.
Sun, May 1, 2016 10:16 AM
