Service manual for D6C with D333
Showing 1 to 10 of 23 results
ETD66SS
Send a private message to ETD66SS
When I bought my D6C I bought a set of JENSALES service manuals from Yesterday's Tractor. Back then I didn't know that the D6C had a few different engines. The service manuals I have, only cover the 4.75" bore engines. I've been searching eBay for a while now for service manuals that include the 10K machines with D333 engine, never had any luck finding any. Does anyone know if there are reprints available of the older service manuals that include the D333?
The JENSALES manuals I have include a code on the front cover, CT-S-D6C 10K1+ Can I assume everything else in the manual is kosher for my 10K401 machine? In terms of the trans, clutches, UC, etc.
Mon, Apr 11, 2016 6:35 PM
catsilver
Your 10K does have the 4.75" bore D333C engine. The later one is the 3306 with its own serial number but most specs are the same. It is the earlier D6C with an "A" in the serial number prefix which has the old 4.5" bore D333B.
Mon, Apr 11, 2016 8:26 PM
ETD66SS
Reply to catsilver:
Hmm, ok, thanks for the clarification.
Does a D333C have all the porting etc required if I want to add a turbo someday?
Mon, Apr 11, 2016 8:29 PM
Reply to ETD66SS:
You need to sort that out in the parts book. A lot of changes in part numbers for the 10K5984-up turbo engine.
Mon, Apr 11, 2016 9:53 PM
sdmuleman
Send a private message to sdmuleman
I have a parts manual for 10K1-7952 if you need one.
Mon, Apr 11, 2016 10:24 PM
ETD66SS
Reply to sdmuleman:
Aww, just bought one on eBay. But thank you!
Mon, Apr 11, 2016 10:41 PM
sdmuleman
Reply to ETD66SS:
Turns out that was from me.... 😛ound:🤣 Small world I guess.
Mon, Apr 11, 2016 11:47 PM
ETD66SS
Reply to sdmuleman:
Oh my, lmao.
Mon, Apr 11, 2016 11:56 PM
catsilver
Reply to ETD66SS:
Oh my, lmao.
There is more to it than just bolting on a turbo, different pump settings, probably a higher capacity oil pump, piston spray jets in the main bearing webs and different pistons, You will need to take a close look at the parts book.
Tue, Apr 12, 2016 1:21 AM
ETD66SS
Reply to catsilver:
Oh well, I just wanted to look in the parts book to see if it was an option if I ever restore this machine. Sounds like it is more complex than I envisioned.
Tue, Apr 12, 2016 4:14 AM
ETD66SS
Reply to catsilver:
Ok, I was looking back through some old threads doing some research on my D6C, I found a thread with posts from Old Magnet on the various engines over on Yesterday's Tractor: http://forums.yesterdaystractors.com/viewtopic.php?t=662097
Now I am confused if I have a D333B or D333C.
The S/N of my tractor is 10K 401, 1968 non-turbo. So, that would make it a D333B engine?
Some pictures here if they help: https://imgur.com/a/JaG4y
The part number on the block is 5S6777 14
Oddly enough I just found this thread: http://www.acmoc.org/bb/showthread.php?5422-Difference-between-D333C-3306-Cyl-Block A conversation between D4Dan who I bought this tractor from, and Bob Ont who helped me a lot as a CAT newbie when I bought it...
Fri, Apr 13, 2018 2:22 AM
Veerkamp Open House 2025
| Placerville, CA
Stradsett Park Vintage Rally
Chapter 2 The Link Club's AGM
