D4C starter recoil spring
Showing 1 to 7 of 7 results
Stuss
Send a private message to Stuss
Hi Guys. A mate of mine has a D4C that he has retrieved from the scrappers and got it all together and going but wants the starter (buzz bomb ) recoil spring for the wire rope .
If someone has a parts book to get number for the spring would be appreciated . Not sure that he'll get one though.
He is 4 hrs away from me , says he can't find serial no, the service manual is for a 39A 1 up.
Wed, Mar 23, 2016 4:23 PM
catsilver
39A, 24A D4C, 60A and 72A 955H used the same starter motor, I reckon the D6B and 977H also used the same base unit, I believe the recoil start cables will be all the same.
Wed, Mar 23, 2016 7:00 PM
seiscat
Reply to catsilver:
The parts book for the early D6B 44A shows the spring assembly to be 2M7846.
Wed, Mar 23, 2016 7:37 PM
EL300B
Send a private message to EL300B
Reply to seiscat:
Unless he wants it for a collector take that buzzbomb off and throw it in the scrap pile.I changed mine over to a 12 volt starter and works great.Cost me $140 for a rebuilt starter and it bolted right up,and put a 4D battery in it.
Wed, Mar 23, 2016 11:03 PM
catsilver
Reply to EL300B:
He will also need new pre-chambers and glow plugs if he wants it to start reliably without ether.
Wed, Mar 23, 2016 11:44 PM
EL300B
Reply to catsilver:
Been 15 years now and used ether on it all that time.Not a fan of ether but go light with it and won't be a problem.Worked for a cat dealer and changed over a few pre-chambers to glow plugs and thought it was a waste of money.Pre-chamber engines seem to tolerate ether better than direct injection engines.
Thu, Mar 24, 2016 12:12 AM
Dozerman51
Reply to EL300B:
There you go again EL300B, booting the "Buzz Bomb" to the curb. Not nice, not nice.:whoo:
Thu, Mar 24, 2016 9:26 AM
EL300B
Reply to Dozerman51:
Guess I've fought them too much.
Thu, Mar 24, 2016 12:55 PM
Veerkamp Open House 2025
| Placerville, CA
Stradsett Park Vintage Rally
Chapter 2 The Link Club's AGM
