Pull scraper for D2
Pull scraper for D2
Showing 1 to 10 of 23 results
mcclan_9
Send a private message to mcclan_9
Anybody on here ever build a pull type scraper? If so do you have any plans you'd be willing to share? I would really like one for my D2.
D2-4U 2065
Fri, Jan 18, 2008 12:56 AM
7upuller
Hi McClan,
Caterpillar came out with a hydraulic pull scraper # 40 that was designed for the D4 in around 1949. The 60 cable scraper for the D6, #70 for the 7, #80 for the 8, and #90 for the D9. Later these cable scrapers were called different #'s, 435, Etc...If someone could help me with more modern # for can and what units the were pulled by I need imput.
As for your D-2 scraper hook up there are others that make 'em. I've seen Bee-Gee models and such. Your ? is the same I had a few years ago. It led me to a 4-40, 6-60, and now this๐Ÿ˜ฎ :
Fri, Jan 18, 2008 1:28 AM
Reply to 7upuller:
Hi McClan,
What about finding a Carrymore?
See photo.
Fri, Jan 18, 2008 2:35 AM
Thank you received: 60
Reply to drujinin:
See photo.
Hi Glen,
I'm looking through the Cat Serial/Product ID book and it looks to me like pull cans ended with cable operation and the only unit that got hydraulics was the #40. Everything else turned into motor scrapers of various types.
Could be wrong and if so I'm sure I'll hear about it๐Ÿ˜„ ๐Ÿ˜„
The 435 you mention is a 13 yd cable unit.
The last of the two axle tractor scrapers was the 666B, 40 yd/54 heaped that weighed in at 149,500 lbs. with tandem power, 56 ft - 8 in long
Gets pretty messy to identify comparison motor scraper replacement units other than by yardage capacity.
If it's just later cable can model #s your looking for try these:
428 (12.5 yd)
428B (13 yd)
435 (13 yd)
435 C&D (15 yd)
435E (12 yd)
435F (14 yd)
442B (14 yd)
456 (18 yd)
456B (19.5 yd)
463 (18 yd)
463C (21 yd)
463E (18 yd)
463F (21 yd)
470 (18 yd)
470B (19.5 yd)
482B (24 yd)
482C (27 yd)
491B&C (27 yd)
There probably are more but it is to time consuming to check all the numbers.
Fri, Jan 18, 2008 3:57 AM
Willie
Hi Glen,
428 (12.5 yd)
428B (13 yd)
435 (13 yd)
435 C&D (15 yd)
435E (12 yd)
435F (14 yd)
442B (14 yd)
456 (18 yd)
456B (19.5 yd)
463 (18 yd)
463C (21 yd)
463E (18 yd)
463F (21 yd)
470 (18 yd)
470B (19.5 yd)
482B (24 yd)
482C (27 yd)
491B&C (27 yd)
Murray made lots of the little scrapers for D2&D4s in this area but most dont want to part with them. heres 1 a guy pulled wit and IH I9 and I used to have 1 that puled with a T20 but it had side wheels but had apron and all.
Fri, Jan 18, 2008 4:36 AM
B4D2
Reply to Willie:
That D2 is pulling a C-45 belonging to Chuck C. He has done a nice job of restoring it. I have a LaPlant Choate C-20, which is basically an Airborne scraper with a gooseneck. Here's a pic of both of them after we went and picked mine up.
Fri, Jan 18, 2008 7:39 AM
gwhdiesel75
Reply to B4D2:
Bruce, a nice looking little scraper. GWH
Fri, Jan 18, 2008 8:34 AM
Willie
Reply to B4D2:
Another try
7upuller
Reply to gwhdiesel75:
Old Magnet,
Currently looking for the 70,80,90 models๐Ÿ˜„ just gotta get one of each for Play Days๐Ÿ˜„ ๐Ÿ˜„ ๐Ÿ˜„
Fri, Jan 18, 2008 8:37 AM
terrywelch_archive
Reply to 7upuller:
Old Magnet,
Chuck has done a nice job restoring it. It works well also. He moved a lot of dirt with it that day.
Fri, Jan 18, 2008 9:08 AM
FarmerD5
Send a private message to FarmerD5
Reply to terrywelch_archive:
Chuck C, do you have some pictures behind the fuel tank of ur Cat D2-5U so that i can see what look like. Hydraulic lines and the remote rear end quick couplers. Thanks
FarmerD5
Fri, Jan 18, 2008 4:03 PM
