D2 3j generator setup?
Showing 1 to 10 of 13 results
ThomasMueller
Send a private message to ThomasMueller
I'm pretty sure my D2 originally had lights as it had most of the wiring still on it when I got it, but was missing the generator and lights. I found some lights and a delco remmy generator the kind that doesn't need a battery and was hoping to rig it up to make the lights work. My question is does anyone have a picture of the mounting bracket for the generator as its pretty tight behind the engine side guard, and I can't figure out how it's supposed to go in there. Do I have to cut a hole out of this guard for clearance? I made new guards as they were missing when I got the cat due to worn out bushings on the roller frames. I think this may also be why the generator was removed. Also don't want a Mickey Mouse setup to adjust belt tension... Thanks
Mon, Mar 21, 2016 11:25 AM
Dandy Dave
Send a private message to Dandy Dave
All the generators I have seen on D-2's were gear driven right off of the engine and were an option. Never seen a belt driven one. Dandy Dave!
Mon, Mar 21, 2016 7:12 PM
mog5858
Reply to Dandy Dave:
my is belt driving factory i see if i can dig up some pic of the bracket for you it bolts to the motor on the bottom passenger side and used it own belt. is your crank pulley a dubble
Mon, Mar 21, 2016 7:41 PM
ThomasMueller
Reply to mog5858:
Yep the crank pulpy is double and would that be the 4 holes on the lower front end of the block or the bracket that holds up the radiator?
Mon, Mar 21, 2016 8:13 PM
Thank you received: 24
Reply to ThomasMueller:
Here are some pictures from Form 6700, the 3J1-5000 parts manual. The battery generator (third picture) is a bit shorter than the battery-less (second picture) and you can see part of the bracket that bolts to the cylinder block behind it. I also posted what looks like a U-series style generator (first picture) with the front plate that permits flange-mounting. The manual doesn't say much about these options but I'm guessing the flange mount probably has a bracket to bolt it to the block, rather than the gear train housing attachment style that the U-series uses. (Note - there are more generator part numbers than just those three but these are representative of the mounting styles)
[attachment=34479]IMG_2477.JPG[/attachment]
[attachment=34480]IMG_2478.JPG[/attachment]
[attachment=34481]IMG_2476.JPG[/attachment]
Mon, Mar 21, 2016 8:48 PM
ag-mike
really hard to find, especially a complete setup. i had a j r2 that had a belt genny on it. good luck
Mon, Mar 21, 2016 8:50 PM
JoeWestfall
Send a private message to JoeWestfall
Reply to ag-mike:
Hi Thomas,
I have all of these items if you want.
Generator,bracket and band clamp.
Side guards wont need modification.
Joe Westfall
Mon, Mar 21, 2016 9:54 PM
ThomasMueller
Reply to JoeWestfall:
Hi Thomas,
Joe Westfall
Where are you located? I'm 20 min north of reddeer? Thanks
Tue, Mar 22, 2016 1:42 AM
JoeWestfall
Hi Thomas,
Located 15 mins west of Spruce Grove.
780-777-3454.
Joe
Tue, Mar 22, 2016 3:08 AM
Hi Thomas,
780-777-3454.
Joe
Hi Joe, I don't suppose you have two sets?
Thomas, there are 6v LED lights with bayonet fittings available - that might give you a bit more lighting punch than filament bulbs, and the light fitting will still look original.
Tue, Mar 22, 2016 3:21 AM
JoeWestfall
Hi Neil,
No, just the one set.
Where do you get LED lights that look original?
Is there 24 volt available?
Joe
Tue, Mar 22, 2016 4:10 AM
