3J D2 direct start question
Showing 1 to 10 of 32 results
TOGNOT
Ok - I have about had it with fixing the pony game. After searching I see a lot of stuff from old magnet, but none of the links work (for me). I know I need to cut a hole in the case, my good friend will do that for me
( right? Mike?)
What part number do I need for the correct starter to use?
The tractor lives in central Cal, will never see freezing temps. I can build the battery tray, wiring etc. But would like to see how others have succeeded at this .
Sorry I could not find this - I'm sure it's here somewhere !
Wed, Mar 2, 2016 10:48 AM
Dozerman51
Are you going to remove the Bell housing to do the drilling? From what I've been told, it's always better to do it that way than trying to drill the hole with the Bell housing in place.
Wed, Mar 2, 2016 11:26 AM
7upuller
Hey Tognot,
OldMagnet attended CatNight tonight. He will be traveling tomorrow. I'm sure he will be looking in soon.
My 5j has DE start. The batteries sit where the pony was. They are special narrow sized batteries by Cat that fit right in the spot. I just put new ones in today. I'll have OilSlick take pictures tomorrow and post.
Glen
Wed, Mar 2, 2016 11:31 AM
Oil Slick
Reply to 7upuller:
Hey Tognot,
Glen
Hey Not Head, you just did a bunch of pony motor tuning and fixing it's clutch. You were so happy it was starting on the first rope pull. Now just take the pony back off and figure out why it's knocking. Your nice narrow gage orchard model will retain its value better if kept original with the proper color. It will probably cost more money and labor converting it to direct start.
My D7 that your using cost me about $800 to convert it over to direct start. It already had the hole in the bell housing while you don't.
Since I can't post pics I'll text them to you tomorrow.
Wed, Mar 2, 2016 11:59 AM
TOGNOT
Reply to Oil Slick:
Thanks dozerman - that's a piece of info I didn't know. I have heard its tough to get the hole exactly correct.
I figure oil slick could do that if he'd quit whining about my tractor's color
Thanks 7puller keep an eye on mike.
Wed, Mar 2, 2016 12:55 PM
Thank you received: 12
Reply to TOGNOT:
Are bell housings interchangeable from the j series to the u series?
Wed, Mar 2, 2016 9:26 PM
TOGNOT
Reply to Ray54:
Also, does anyone have personal experience with the kit that bolts on top of the case ( takes the place of the pony) ? A starter then spins the original pony idler gear - you keep the original pinion.
It seems some think it's a bad idea, but others have said it works great.
I don't know about interchange with the bell housings....
Wed, Mar 2, 2016 11:28 PM
restore49
Reply to TOGNOT:
I just left my Pony there when I added the starter on my D2 5U - found my starters (4) at a scrape yard dirt cheap. The measurements for center point for hole is available - just takes a little time and patience to drill.
Thu, Mar 3, 2016 3:46 AM
TOGNOT
Reply to restore49:
Restore49, which starter did you use ?
I read a Delco 42 MT was correct. What vehicles did the starter I need come on if I go the wrecking yard route ?
Thu, Mar 3, 2016 5:26 AM
restore49
Reply to TOGNOT:
42MT - I just downloaded a photo to take to the yard - easy to tell the difference. Found a company that would sell just the beveled gear for original Bendix on my junkyard 42MT. The 42MT is very easy to work on / rebuild. Eric Jensen started a thread with a lot of info. I could ship you one but the postage would be a killer. I think there are some photos of my installation - solenoid down which is working just fine.
Thu, Mar 3, 2016 8:46 AM
TOGNOT
Reply to restore49:
Ok thanks.
I finally was able to find old magnets site regarding this and all the info is there.
I will follow up with whatever I do.
Thu, Mar 3, 2016 9:27 AM
Newby Hall Tractor Fest
