#12 7t grader help
#12 7t grader help
Showing 1 to 10 of 37 results
mog5858
well guys i was out to get everything ready for her transport home but i am having steering problems well had. i could not steer at all ,lifted the blade off the ground and the wheels would move by hand. my has the Behlen power steering add-on. the shaft was turning going in to the front gear box but i could not get nothing out of the Pittman arm at the bottom. as i keep working it back and forth i would be about 1/3 of a turn from the steering wheel before it would stop hard and i did pull on it good but then it just started going and i could feel the power steering working? it had be running for a good 30 min up to this point it's about 22 out today so i thinking i might have ice somewhere? is that front box to have grease or oil in it? it has a oil fill line that's why i was thinking oil not grease. second how would one add oil/change the oil in my power steering i can't find no fill port. OIH you will have to dig out that book for me and do a little reading. dose someone have a pic of the shitting pattern as my is very rusty i have found a forward and revers but would like to know what i am in. my operator's book said to see shift pattern on the grader lol. the main clutch need a little tlc is there a more detailed info on adjustment that than what is said in the operator book as it's only a little pic and a few words? i have to pull the clutch up right now to engage it but was able to walk up out of the hole she was in so i doing think it's slipping too bad. thanks for all your help boys.
[img]http://i263.photobucket.com/albums/ii123/mog5858/cat%20212%20grader/12%20cat%20grader/1d63aa3c-b37e-4e94-945f-8757ece0413d_zps7y2oeygz.jpg[/img]
[img]http://i263.photobucket.com/albums/ii123/mog5858/cat%20212%20grader/12%20cat%20grader/IMG_0244_zpsb947cqed.jpg[/img]
[img]http://i263.photobucket.com/albums/ii123/mog5858/cat%20212%20grader/12%20cat%20grader/IMG_0234_zps7izanc3k.jpg[/img]
[img]http://i263.photobucket.com/albums/ii123/mog5858/cat%20212%20grader/12%20cat%20grader/IMG_0238_zpsbpy2t31o.jpg[/img]
Mon, Feb 29, 2016 3:54 AM
Thank you received: 12
Hi, Mog5858.
I'm thinking your shift pattern is going to be a standard 'H' pattern with reverse to the front and 1st to the rear nearest your right leg and Hi/Lo on the second stick. When changing up or down, you move the range lever every change in sequence and the main box every only every second change. F'rinstance, 1st gear is 1st position in the main box and Lo in the range box while 2nd is '1st' in the main box and Hi in the range box. '3rd' gear would be '2nd' in the main box and Lo in the range box - and so on. This arrangement also gave you a Hi and a Lo reverse.
Your climate may well be a factor in your steering issues. When you do get moving, I would advise using the lean wheels along with the steering wheel to reduce the load on the front steering box and the down shaft 'cos it was not uncommon to break either the steering box or the down shaft with the earlier power steering adaptations that had the 'force' applied to the steering column before the steering box.
Cat eventually built a system that had the power steering ram down at the bottom of the down shaft to minimize these breakages.
Mon, Feb 29, 2016 8:20 AM
Hi, Mog5858.
The steering box takes 90wt gear oil.
Couldn't find the shift pattern for the 7T but here is the 8T. Not sure it's the same but might be.
That grease zerk is supposed to be the fill level plug.
Mon, Feb 29, 2016 10:40 AM
Hi, Mog5858.
Oooops. Sorry. I had the 1st-reverse and 2nd-3rd slots on the wrong sides of the main box, 1st-reverse being AWAY from your right leg, as per Old Magnet's picture. Maybe I need a refresher course on 'em but it's only been about 32 years since I was last operating one. Could I REALLY forget that quickly?
A kew-ree-yuss mind would like to know.
Mon, Feb 29, 2016 11:22 AM
kracked1
Hi, Mog5858.
My guess is the lower seal in the steering box went bad so a zerk was added and gun grease was used. Clean it out and use 00 grease, also known as cornhead grease.
Mon, Feb 29, 2016 9:12 PM
kracked1
Reply to kracked1:
Also on a 8T I use a 3/16 drill bit to set the distance between throwout bearing and pressure plate fingers. Takes a couple rotations to get them all even as they will change as the next one gets set.
Mon, Feb 29, 2016 9:15 PM
vmfhlg85
Send a private message to vmfhlg85
Reply to kracked1:
Sure looks like a 9K to me.. Nice looking nevertheless..
Tue, Mar 1, 2016 1:57 AM
mog5858
Reply to vmfhlg85:
thanks for the the pick OM. Deas it make sense now that i think about it with a grader being back wards well if you would like to have a refresher cores on one come on up i sure i will have learn some bad habits you will have to brake me of as i a complete new to grading lol. it's a 7t-2347 with 4600 built in 1946 i think it was the next year they came out with the 318. thanks for the info on the steering box i will get it cleaned out and see what i find inside when i get back to my buddy shop.
Tue, Mar 1, 2016 6:42 AM
Reply to mog5858:
Hi, Mog5858.
I gotta better idea. How about you get yourself down to Santa Margarita for Memorial Day Weekend and we'll try to get Glen to take his 99E Cat 12 down there for the show to help with the clean-up afterwards. Heck, we might even be able to eradicate some of O-I-H's bad habits at the same time. LOL.
Tue, Mar 1, 2016 6:56 AM
old-iron-habit
Hi, Mog5858.
Hi Martin,
My 212 had a lot of condensation water in every gearbox and compartment when I bought it. My steering box had over a quart. I drained all and replaced with all new lube. I would be very careful running the blade and controls with out checking them by loosening the plugs. But the water has to be thawed to do so. Ice in the boxes is not your friend. Chain boxes might have ice also.
Tue, Mar 1, 2016 10:28 AM
mog5858
Reply to old-iron-habit:
Hi Martin,
well Deas i would love to make it down there this year. i don't think it's going to happen the way the dallier is right now (we down 30%) and plus i bean buying too meany cat's so the travel fun takes a hit lol. but i will not miss 2017 i will be there for sure. hey OIH where to i fill my power steering set up with new oil. do i just drain from a line and refill the line? i would think that would let some air in.
Thu, Mar 3, 2016 5:32 AM
Veerkamp Open House 2025
| Placerville, CA
Stradsett Park Vintage Rally
Chapter 2 The Link Club's AGM
