Hyster D4N winch parts
Showing 1 to 7 of 7 results
JoeG
Send a private message to JoeG
I am in need of some gears to put my winch back in order. Was wondering if anyone had any leads on where to buy parts for the old Hysters or is it now just a boat anchor and I should look for a replacement for it?
Tue, Feb 9, 2016 6:48 PM
Hillbillybjopkr
Send a private message to Hillbillybjopkr
have a local parts guy trying to find out some info on a D4 winch from Allied in Portland
Wed, Feb 10, 2016 3:25 AM
Inter674
Reply to Hillbillybjopkr:
I contacted them for D4 and D2 winch parts with no success.
I also searched for parts for a year or so but ended up getting a gear and shaft re-made - ouch!
Bearings were easy to find but seals were not.
You should have greater chance of success tho especially to find one being wrecked.
I think many winches here in Aus were easy pickings for scrap.
Good luck.
Wed, Feb 10, 2016 3:35 AM
rogerjmartin
Send a private message to rogerjmartin
Reply to Inter674:
Good luck.
I have a complete Hyster D4 Winch that I would sell. It is complete except for the control levers. Everything turns and looks good inside it. I've never used it. Roger Martin, southwest Ohio, 937-477-5270 or email: [email protected]
Wed, Feb 10, 2016 5:08 AM
Hillbillybjopkr
Reply to rogerjmartin:
I'm actually looking for just the control handle....I know my winch turns...just did it one day.......but I'm sure needs a rebuild....stil looking myself
Wed, Feb 10, 2016 1:15 PM
JoeG
I just want to give this a bump and update it a little. I'm still looking for a winch. I have found a D4 hyster or two out there but none with controls and the controls for these winches are different. My Father has a D4 winch on his tractor and I guess I plan to stick with my N series at this point. Also I have found the gears I need will not interchange between the two winches, the N series uses a 32 tooth sliding gear while the D4 series uses a 28 tooth, both have different part numbers as do the intermediate shafts used in each series. I have further found that the intermediate shaft, which has two gears integral to it, so one can't just replace one gear, you need the entire shaft.
All this probably means finding another winch for parts. I'm hoping someone has one kicking around with no controls that they would part with. If anyone knows of one, I'd love to hear about it.
Thanks,
Joe
Wed, Apr 5, 2017 6:40 PM
D8PETE
Send a private message to D8PETE
Reply to JoeG:
Thanks,
Joe
Joe - Have you tried contacting General Gear in ID?
Wed, Apr 5, 2017 7:36 PM
JoeG
Reply to D8PETE:
Nothing on their site. I emailed them to see if I missed something.
Wed, Apr 5, 2017 10:35 PM
